BMW M3 Forum (E90 E92)
EXXEL Distributions
      11-09-2013, 10:42 PM   #1
Boostin FD
Bored all the time
Boostin FD's Avatar
Drives: Batmobile
How to remove door handle?
I'm gonna attempt my first vinyl wrap DIY and can't find a thread on how to remove the door handles. I see a lot of people that did a vinyl wrap remove the door handles for easy wrap... Anybody have a link? I searched here and found nothing.
Not sure if door panel needs to be removed...
Thanks.
Current: 2014 991 Turbo RS
Past: 15 GT3, 17 R8 SC, Two 16 M4 GTS’s, Two 18 GT350R's, Two 13 RS5’s, 13 M3, 10 R8, 15 M4, 09 M3, 04 M3, 09 S5, 02 M3...
It all started with an RX-7 (FD).
      11-11-2013, 07:51 AM   #2
Boostin FD
Bored all the time
Boostin FD's Avatar
Drives: Batmobile
anyone?
      11-27-2013, 11:29 AM   #3
LucWerkz
Drives: e70 X5 4.8i (Temporarily)
Originally Posted by Boostin FD View Post
anyone?
PM me any questions you may have. I'd type out a DIY but I'm at work at the moment.
      11-27-2013, 11:44 AM   #4
the_road_less_traveled
Id rather be boating...
the_road_less_traveled's Avatar
Drives: Baja 26 Outlaw
Door Handle is extremely easy to remove. Open door and look for rubber trim located in jamb on door at same elevation as handle. remove rubber by gently pulling away from door with just your hand. Behind the rubber are two holes. One hole has a hex head (6mm maybe?) bold that secures the handle. Loosen it. It doesn't come out of the hole though by design. Pull lock out then you can remove handle. Led light needs to be unhooked before handle comes out too. Lastly remove handle electric cable and you done. It's literally a 5 minute job.
      12-07-2013, 09:14 PM   #5
XYR03
Drives: Cayman S
Now putting it back on is the tricky part. Take your time and try aligning the LEDs correctly. Its not as easy as taking them off.
[SIGPIC]2015-Cayman S (Can't leave bimmerpost)
2009-E92 M3
2005-E46 M3
1998-E36 M3
2007-E92 328i[/SIGPIC]
m3post
