Under body damage
11-06-2013, 02:59 PM | #1 |
Rep 4
Under body damage
Hi,
At the parking today i ran into a curb which was a bit longer than usual... little bit of the undercover plastic has come off and scratches at the bottom: how serious is this, will it cost a lot to fix? please find attached the images.. Last edited by kambmw; 11-06-2013 at 03:13 PM.. Reason: images not showing |
11-06-2013, 03:04 PM | #2 |
Rep 128
lol your probably fine if it was just the undercover. Mine has a good tear in it running straight over a log in the road once, thank god it went directly under the car and I didn't hit it with my wheels.
COBB||VRSF||BMS
11-06-2013, 03:38 PM | #4 |
Rep 670
you could replace your jack pad. I wouldn't worry about the rest.
2010 335i e90 Le Mans Blue/Chestnut Brown | M-Sport | 6MT
11-06-2013, 04:40 PM | #5 |
Kraut Driver
59
Rep 624
Drives: 2014 650i GC/2011 335is DCT
Might as well take it to the junkyard, it's done for.
11-07-2013, 10:34 AM | #10 |
Master Gunner
77
Rep 435
Drives: 2008 335i Sport
I would either trim the loose, ragged edge of the underbody panel, or replace it outright. It appears to be the left side, which is ~$70 online; the right side is only ~$30. I had to replace my left side when I drove without the engine cover and the sheer force of wind at highway speeds caused the transmission cover section, acting like a giant scoop, to break off the mounting points on the left underbody panel, trashing not only that panel, but the transmission cover as well as it scraped against the freeway.
All the underbody panels are easy to replace (so long as you have a jack, or preferably, ramps) as they are held in place by numerous 8mm bolts and a couple 10mm nuts.
2008 335i Alpine White Sport Sedan AT | Avant Garde M364 Staggered 19"
