Opinion on Auto Transmission
11-05-2013, 04:22 PM | #1 |
Rep 66
I have a 06 325i with about 114,000 on the clock and i brought it in to a reputable transmission shop and they told me I needed a new transmission that will cost $6100 and was wondering if i should get another shops opinion that actually works on BMW's or not. The car does slip from 4th to 5th under load and the code that was pulled when the yellow transmission light came on was 4F8A which is a gear ratio error i believe. I have changed the fluid on it but have not changed the filter, so i'm wondering if i should change the filter with new fluid, will it make a difference?
11-05-2013, 04:55 PM | #2 |
Rep 2,431
Get a second opinion. If they say the same thing start looking for a new car.
My speeding isn't the problem. It's the Slow Folks ahead of me that cause accidents!
11-05-2013, 05:14 PM | #4 |
Rep 629
Can you do a fluid and filter change on these autos? I've heard of people having success with slipping transmissions on other makes. I know this is supposed to be a maintenance free unit though...
11-05-2013, 05:17 PM | #6 |
Rep 66
11-05-2013, 05:18 PM | #7 |
Rep 66
Yes you can on these, i do not believe BMW when they they it is maintenance free because auto transmission fluid will always degrade no matter who makes them.
11-05-2013, 05:25 PM | #8 | |
Rep 629
11-05-2013, 05:38 PM | #9 |
just another bmw douche bag
195
Rep 3,640
FYI, the filter is built into the oil pan on the 325i. If you change the pan, you also change the filter. If the fluid is new, you should be able to drain and re-use it if it's still clean.
11-05-2013, 07:21 PM | #10 |
douchebaggo
186
Rep 972
$6k is for a reman AT. A used AT will probably cost you half of that at most. You will have to weigh the difference in warrant on both those options. If you plan to keep the car for a long time, then the factory reman AT is probably better. But damn, a $6k repair on a 6yo car is a tough pill to swallow.
11-05-2013, 09:52 PM | #11 | |
Rep 66
11-05-2013, 10:13 PM | #12 |
Rep 1,311
Nothing is "maintenance free". Get a second opinion from a true blue BMW mech. and see what he says. If it does come down to getting a trans. salvage one dude.
11-05-2013, 10:18 PM | #13 |
Rep 66
Thanks for the response, I'm definitely getting a second opinion, but do you think salvaging one is worth the hassle? will it be reliable still?, the last thing i want to do is waste money
11-05-2013, 10:38 PM | #14 | |
Rep 1,311
11-05-2013, 11:48 PM | #15 |
Rep 3,552
There are e90 transmission on ebay going from 900-2000, buy it and find a place to install.
12.0 @ 117 |
11-06-2013, 12:11 AM | #16 | |
Rep 66
11-06-2013, 12:12 AM | #17 |
Rep 66
11-06-2013, 12:14 AM | #18 |
Rep 1,710
Do a 6MT?
DONE: Seibon CF Hood, M3 Rep, MSport rear w/DD CF Diffuser, M3 Rep Skirts, Seibon CSL trunklid, Forgestar F14 18s w/Michelin PSS, Eisenmann catback, AA Headers, BPC Stage 2, Charcoal Delete+revMotor+AFE Drop In filter
FUTURE MODS: LED headlights, CF rooftop, M3 Suspension Conversion, Dinan CAI Mod |
11-06-2013, 02:59 AM | #20 |
Rep 1,710
LOL, well I would do an MT, doesn't necessarily have to be from an E90, could be from an E46.
11-06-2013, 09:47 AM | #21 | |
Rep 1,311
11-06-2013, 12:12 PM | #22 |
195
Rep 3,640
Any reputable auto recycler will offer some sort of limited warranty on the part you buy. Typically, you'll see a 90 day warranty or similar on used engines/transmissions. Sometimes longer. That should be long enough to tell if something isn't right.
That said, most of these transmissions last a good amount of time, and it's actually kinda rare to hear these kinds of problems at this mileage. I'd say find a used trans, and get it installed with a new pan and fluid. Make sure you get the right fluid for your trans (the ZF trans is different than the GM one found in the 328i) |
