11-01-2013, 11:40 PM | #1 |
Rep 3,387
DIY: How to install a 3-way OBDII splitter/replicator
Time allotment: 30-45 mins What you need to purchase: 1) This bracket: http://www.ebay.com/itm/200901287023 2) This ODB II splitter http://www.ebay.com/itm/321221830865 What tools you'll need: a) Phillips head screwdriver b) small torx set c) trim removal tool d) mini flat head screwdriver 1. Use the Phillips screwdriver to remove the hood release handle. There will be another screw now visible. Use the torx to remove it. 2. Pull back the door weather stripping by the dash, then remove the black, plastic door trim. Remove the kick panel surrounding the OBD II port by carefully pulling it towards the transmission tunnel. There will be 2 snap clips, one in the lower middle of the panel, and the other will be visible when you remove the weather stripping. Use the trim removal tool and remove the snap connector closest to the trunk release, and put it in the appropriate place in the kick panel. (Trust me on this one). 3. Push the trunk release button from behind to release it from the kick panel. Rotate it around so you can see how the wire harness clips into the release. Use a miniature flat head screwdriver to release it. Set it, and the kick panel, to the side. 4. Use the torx to unscrew the lower dash panel screws. You only need to remove the one closest to the door, and the screw to the right of it (2 out of 3). 5. There are 2 Phillips screws that attach the OEM OBD II port to the car. Remove them both. 6. Take the OEM harness and plug it into the replicator. 7. Take the first connector in the series and plug it into the aftermarket bracket. 8. Plug in any auxiliary devices into the remaining 2 connectors. Pull down a bit on the lower dash panel and shove those 2 connectors up there. Screw the panel back in to place. 9. Screw the new bracket in place. 10. The orientation and location of the OEM harness/replicator connection is crucial in making sure the kick panel fits back into place smoothly, I can't stress that enough. When positioning, make sure the trunk release harness is as shown to make it easier to reconnect. Check the picture. 11. Put the kick panel back into place. That top snap connector you removed in step 2? The kick panel goes in place a lot easier when in the snap connector is in the kick panel vs having to slide the kick panel over the snap connector. Make sure the the trunk release wiring is still accessible, and then plug in the trunk release button. 12. Put the door trim back in place, followed by the weather stripping, and finally, the OBD II access cover. Last edited by whats77inaname; 11-02-2013 at 08:33 AM.. |
11-03-2013, 09:20 AM | #3 | |
Rep 3,387
and one of these (BT OBD II adapter) and they both need to be plugged into the OBD II port in order to work. 1 port = problem. 3 ports = no problems. |
11-06-2013, 05:20 PM | #4 |
Rep 548
Great idea!!
Is there anything special about that splitter (other than it being 1 to 3 way) vs others, such as one like this? I only need one extra port for my P3 gauge. |
11-06-2013, 05:37 PM | #5 | |
Rep 3,387
http://www.ebay.com/itm/321221831560 I received it about 10 days after purchase. |
11-24-2013, 12:29 PM | #6 |
Chief Warrant Officer 4
53
Rep 726
Drives: 335I, E46 M3, X5M
Glad I ran across this. Thanks for the write up
11-24-2013, 02:00 PM | #7 | |
I know a thing or 2 about a thing or 2...
3101
Rep 3,470
Drives: E36 M3 Coupe, e39 M5, i3s
2019 Imperial Blue Metallic i3s BEV
2003 Le Mans Blue e39 M5 Dinan S1 1997 Alpine White e36 M3 (the old gal) 2013 Mineral White e92 M3 (sold ) 2014 Carbon Black 650i M-sport (sold) |
11-24-2013, 05:11 PM | #8 | |
Rep 3,387
The P3 boost gauge will display boost when/if I sc. I'm debating it still. The main reason I'm doing it is b/c of the tablet I'm installing in the car to replace the CCC system. I use Torque Pro: https://play.google.com/store/apps/d...g.prowl.torque with https://play.google.com/store/apps/d...meterfortorque and https://play.google.com/store/apps/d...prowl.recorder |
11-25-2013, 09:15 AM | #9 |
Mr. Nice Says Hello
635
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
Very cool, thanks for sharing
10-17-2014, 06:40 PM | #11 |
Rep 3,387
Bracket is now available again (have not seen it sold separately in quite a bit of time):
www.ebay.com/itm/191212490542 Last edited by whats77inaname; 10-17-2014 at 08:41 PM.. |
10-28-2014, 08:51 AM | #12 |
Rep 398
Thanks for sharing, I just ordered a splitter and the bracket so I can leave my WIFI adapter plugged in and still have an OBDII port open. Winter project when I get bored!
'17 Porsche C4S Sapphire Blue Metallic / Bordeaux Red - Softronic tune - Soul Sport Cats - Soul Exhaust
'13 E70 X5M Black Sapphire Metallic / Bamboo Beige - Full Dinan Suspension - Dinan Exhaust - BPM Sport Tune - xHP Flashtool Transmission Tune |
04-11-2015, 11:20 AM | #13 |
Rep 14
One question, I saw this post http://f30.bimmerpost.com/forums/sho...d.php?t=847391
I assume that you don't have this problem "the two OBD2 devices would take turns connecting - which didn't really do what I wanted. Basically device A would get data, then device B would connect kicking out device A, then device A would connect kicking out device B etc etc - not desirable." Sorry for my bad english. |
04-14-2015, 09:34 PM | #14 | |
Rep 3,387
04-22-2015, 11:48 AM | #15 |
Rep 398
I would like to do this, however the WIFI adapter that I am using does not "turn on" if I leave it plugged into the OBDII port and shut the car off. When I turn the car back on, I have to unplug the adapter and plug it back in to have it broadcast WIFI again. I'm using the below Vgate one from Amazon.
http://www.amazon.com/BestDealUSA-Wi...or+iPhone+5+4S From reading the reviews, it is a problem with this adapter, should have read more into it before buying! Other than this issue, it codes fine with the BMWhat app and the DashCommand app.
'13 E70 X5M Black Sapphire Metallic / Bamboo Beige - Full Dinan Suspension - Dinan Exhaust - BPM Sport Tune - xHP Flashtool Transmission Tune Last edited by Lunker325; 04-22-2015 at 11:59 AM.. |
04-22-2015, 12:12 PM | #16 | |
Rep 3,387
04-22-2015, 01:33 PM | #17 |
Rep 398
Lol, yes indeed!
02-22-2017, 04:49 PM | #18 |
Rep 1,171
Thanks, just installed a p3 vent Guage and used the 2 to 1 splitter. Thanks for the eBay links and writing it up . I could not get my Oem obd as low as you did in the pic but was able to stuff the kick panel shut .
02-22-2017, 10:07 PM | #20 |
Rep 3,387
Glad everything worked out and that so many people are getting use out of this
