335Is part question
11-01-2013, 12:33 PM | #1 |
Rep 1,143
Drives: 2020 M2C DCT
335Is part question
I have a 2011 335Is. There is a small flap of rubber in front of the front wheels. Not sure of its function but one ripped and fell off. It is not a separate piece but I can not tell if it is part of the front lip or the chassis. Does anyone know what it is and how I can replace it? Or I can just tear off the other one
"The sleep of reason brings forth monsters."
11-01-2013, 12:49 PM | #2 |
I used to be conceited, now I'm perfect.
570
Rep 1,826
Drives: 2018 M3 CS
Not sure if I see it here but look around. You may find it in another section.
http://www.getbmwparts.com/parts/201...iagram=1946013
2018 M3 CS - Alpine White l l
"I used to be conceited. Now I'm perfect" |
11-01-2013, 01:08 PM | #3 |
Rep 3,866
Drives: '23 G80 M3C xDrive; '13 e92 M3
If I'm not mistaken that part is just there to prevent the bumper from getting scratched since the car is low. I don't think it's an issue if it comes off.
2023 G80 M3 Competition xDrive Isle of Man Green on Kyalami Orange full leather - 826M black wheels - Carbon Fiber Trim - Carbon Bucket Seats - Executive/Driving Assist/Parking Packages - Laserlight - M Shadowline Lights - M Drive Pro - CS Trans/Diff/Steering Coding
2013 E92 M3 Mineral White on Bamboo Beige noviello leather (Base w/ Nav, Comfort Access, Lighting Pack) - DINAN Stage 1 and Free Flow Axle-Back Exhaust |
11-01-2013, 01:44 PM | #4 |
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
It's supposed to be there, it's either for not scraping like Samaster said or I think it has something to do with lowering the wind noise. One of mine tore off when I was auto crossing last and I haven't noticed anything different at all so I would bet if you took them off since you don't like the way it looks or something then I would bet it's okay to remove them.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
11-01-2013, 01:57 PM | #5 |
Rep 2,015
Go to Realoem.com
Put the last 7 digits of your VIN where it says Serial. Look up your part# and find it on eBay. I believe the part you are looking for is the front fender liner. Regards, DN |
11-01-2013, 02:46 PM | #6 |
Rep 346
This took me too long to confirm so glad to save someone else the trouble (recently replaced on of my 2 when an animal in the road hit it).
Deflector Lip Left: 51757185797 Deflector Lip Right: 51757185798 This is on a part diagram nowhere near where you'd expect and it's difficult to place it's location, but these are in fact the deflectors.
11-01-2013, 09:49 PM | #8 |
Rep 3,866
^yup.
11-01-2013, 09:56 PM | #9 | |
Rep 346
I didn't take it to speeds that would confirm this when my one was detached, but in terms of fluid dynamics (of air, in this case), I couldn't certainly understand that being the case at 130+mph.
11-01-2013, 11:29 PM | #10 | |
Rep 2,017
08-14-2014, 01:35 PM | #11 |
Rep 245
Has anyone confirmed that is the correct Part? I was looking at the car the other day and it seems like it's part of the front side of the liner.
08-18-2014, 12:35 AM | #12 |
Rep 442
Drives: 11 335is Coupe BSM
The part numbers cited here are incorrect - if you buy those you will be taking them back. The 2011 IS has the BMW designated "M-Aero" kit and is a special order. I have yet to see an IPB (Illustrated Parts Breakdown) detailing the M-Aero kit. The deflectors are not two separate parts but one part. The deflectors are part of the underliner that protects the bottom of the engine. It is one piece not two separate pieces. They do deflect air. I crawled under the car and tore my remaining one off and just had that underliner replaced along with the right and left underfelt liners after hitting debris on the freeway. Should have and post the part number when I get the invoice this week.
'11 BSM DCT 7 Spd. 335is | RPi | aFe Magnum Flow Direct Fit | Interad DTM 10 Forged | Smoked Reflectors | Huper Optik Tint | Arkym Rear Diffuser | Cyba CF Quad Tips | iND CF CRT Rear Spoiler | COBB Protune | Turbosmart BPV | AutoCarbon CF Grills | Silver CF e-Brake | BMW CF Mirror Shrouds | M Perf. Steering Wheel v2 | KW DDC Coilovers w/WLAN | Interior Xenon LEDs | Custom 335is Accents | F/R Fenders Rolled & Pulled | New Pipes Baffle Delete
09-20-2014, 03:21 AM | #13 |
Rep 442
Ok - I confirmed that is the part. It is sandwiched between the protective and something else. That is the P/N though so I stand corrected. Will post pictures of the actual part. Just had mu underside replaced do to road debris and these are what they ordered.
09-20-2014, 10:49 AM | #14 |
Rep 207
Drives: 2024 X3M Comp
It is part of the front fender liner. $65-$85 at getbmw. Easy to replace; I just parked on the peak of my slanted driveway, remove around 15 screws, and slide it out - no need to remove the tire or lifting the car. On the "is" the rubber deflector is molded into the fender liner. On the other models the deflector was a separate part that cost $9.
09-29-2014, 03:55 PM | #15 | |
Rep 442
Just had mine replaced and I thought kind of same thing until they pulled it off. I swore it was looking at it but...was wrong. I even made BMW check it over and over thinking they gave me the wrong part. Someone posted the part numbers above which I said were incorrect as I had the parts but, after looking, thought they were wrong so I stand corrected. The nomenclature is: Manufacturer BMW Categories Body and Trim > Interior equipment, lower; Body and Trim > Mounting parts, engine compartment Pressure lip seal, front left 335is Coupe. Required: 1 Stock Code 51627136525 http://parts.bmwofsouthatlanta.com/p...627136525.html Pressure lip seal, front right 335is Coupe. Required: 1 Stock Code 51627136526 http://parts.bmwofsouthatlanta.com/p...627136526.html And here is the IPB (Illustrated Parts Breakdown) showing it - #14 - saying it is part of the Wheel Arch Trim Assembly and when installed fits right in there. Mine are on and these is what they are. http://parts.bmwofsouthatlanta.com/i...ize/251624.jpg
09-29-2014, 04:11 PM | #16 |
Rep 442
Now another 335is part question...in the right front wheel well, the liner is a panel behind which is the oil cooler. On my car this panel is non-vented and I was just told that this is correct and stock from BMW. Do any other 335is drivers have different? This thing is totally closed. I am wondering if I drill holes in it for more ventilation if this will mess up some engineer's design of pressure flow around the thing? If everyone else's IS is closed off then I guess I am up in arms about nothing.
09-29-2014, 09:08 PM | #17 | |
Rep 207
51718047461 - Driver Side 51718047462 - Passenger Side |
09-29-2014, 10:56 PM | #18 |
Rep 1,951
The deflectors in front of the wheels are there for underbody aerodynamics, specifically to reduce drag. Nothing to do with protection of the fender or anything like that.
Probably. I wouldn't mess with it. I don't know anything about the part you mean, and don't have a good idea what you're talking about, but it's definitely true that adding holes through the liner to the airflow under the car will significantly alter airflow in the area, for better or worse.
09-29-2014, 11:36 PM | #19 | |
Rep 442
09-29-2014, 11:42 PM | #20 | |
Rep 442
These are the new "deflectors" same part numbers as the pressure lip seal nomenclature above. Part pictures are below and can be pulled up on the parts links I posted. Apologies for the grainy underside pic. You can see both are tapered in the parts pic and both are tapered on the car. Again, BMW here in Cali sold them to me for $12.00 a piece - double what Atlanta BMW has them for) to me and they are now on the car...
09-30-2014, 02:28 PM | #22 |
Rep 442
That's what I suspected. Think the body shop that replaced my fender liner put that on there - though they say they did not. Time to buy one. Thanks for the post!
