Smart key problem
10-30-2013, 04:49 PM | #1 |
Rep 1,362
So this morning i unlock my car 328i 07 and smart key was working at 11:15 lunch time key was working and at 4:00 leaving work smart key don't work have to used my metal key to open the car i put the key in the ignition and it turns on but it don't unlock or lock the car???
How do you open this and can it be the battery?
10-30-2013, 05:43 PM | #2 |
Rep 136
If its comfort access (i need a back pick to tell you) it would be on the top of the back, if it isnt comfort access you cant open it... and it should charge in the ignition.
10-30-2013, 06:00 PM | #3 |
Rep 473
I have comfort access and i changed the battery when it started acting weird- so you can open them. also if its CA u really wouldn't use it to put in the ignition as that would defeat the purpose of keeping in your pocket or bag.
335i Space Grey Coupe/ppk/ssk/pe exhaust/perf susp
10-30-2013, 06:20 PM | #4 | |
Rep 136
Would you rather have it not working and in your pocket? or have it working and charging in ignition for once in your life? |
10-30-2013, 06:31 PM | #5 |
Rep 473
not quite sure i understand what your getting at because it works fine without it in the ignition and from my understanding is one of the major 'conveniences' of having CA. the fact that it charges it is cool- i didnt know that. but the batteries last quite a long time so if i have to change them every couple years its ok.
10-30-2013, 06:45 PM | #6 |
Rep 519
Drives: E90 "328i" N51
Location: San Diego a.k.a. A Whales Vagina // Cal State San Marcos
its simple. remove the metal key part from the FOB ( or as you call it "smart key"?) and you see an outline of a square. once the key is removed you will see and little clip/notch sticking out… get like a flat head and pry it open in the slot beneath the clip type thing. and to put back reverse.
10-30-2013, 07:02 PM | #7 | |
Rep 136
10-30-2013, 07:42 PM | #8 |
Rep 519
wait… are you saying the fob charges itself while in its slot?
10-30-2013, 08:53 PM | #9 |
Rep 1,362
Is not comfort access and is always in the ignition socket i got my spare key and it works fine... For some reason i can take this one out even if the car is running but the spare one that is brand new stays inside
10-30-2013, 11:12 PM | #10 |
Rep 432
Drives: 2017 BMW M3
sounds like the key is somehow defective
