Battery is bad?? Battery discharge on AM cold starts. 1 code
10-29-2013, 11:53 AM | #1 |
Rep 4,632
Two mornings in a row now I am getting battery discharge messages.
This is the code im getting: My car with the engine off was at around 12.3 volts and with the radio and ignition on, it fell to 11.8 volts.. With the car on its at 14volts.. This is the code im getting: And this is my volts while driving..
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
10-29-2013, 12:09 PM | #2 |
Rep 3,854
Drives: 330i, 135i
dude it will help if you first tell us that your issue is. Are you having low battery warnings?
10-29-2013, 12:16 PM | #3 |
2095
Rep 43,350
The voltage while driving isn't important, that's just the reading you're getting from your alternator. If your having issues starting the car or if your battery is dying after very little use when the car is turned off, your battery is most likely on it's way out.
10-29-2013, 01:08 PM | #4 | |
Rep 4,632
Im getting battery discharge warning in the morning when i start the car
10-29-2013, 01:12 PM | #6 | |
Rep 3,854
Drives: 330i, 135i
Most liekly is your battery. Try to use the defrost and REST features, I bet these dont work due to a low battery. |
10-29-2013, 01:53 PM | #7 | |
Rep 4,632
I went to my mechanic earlier.. About a 5 mins drive.. Opened the trunk, locked the doors, and the car batt volt meter was 12.59v... But like i mentioned the battery discharged icon only comes on in the mornings..
10-29-2013, 01:55 PM | #8 | ||
Rep 4,632
10-29-2013, 09:38 PM | #9 |
BMWCCA 149159
38
Rep 847
The only other situation I can think of is that you don't drive the car 20 minutes as required by BMW to keep the battery in a state of charge. If your commute is very short then you need to use a battery tender or CTEK to keep it charged or it will certainly kill your battery.
10-30-2013, 02:07 PM | #11 |
Rep 373
This is a VERY common issue with these cars -if you take a trip of less than 20 minutes or so the alternatior doesn't have enough time to recharge the battery to make up for the juice consumed in starting the engine. If you drive less than 20 minutes as regular practice (for example if you have a ten minute commute, or use it for short trips to the store) after some time you will get the "excessive discharge" message. It's really poorly worded - it's not excessive discharge that's the problem but rather insufficient recharge. Put a battery tender on it overnight every so often, and/or go for a nice long 45 minute drive once or twice per week and it will go away. This is the only car I've ever had this issue in, and I've owned 4 BMWs, 5 Audis, and a host of others in my career.
F83 M4 convertible, F15 X5 xDrive35i
Previous: E93 335i, E36 328iC, E28 528e, E21 320i |
10-30-2013, 02:16 PM | #12 |
Finnish Flash
19
Rep 55
12.3 volts seems like the battery needs changing. I have the same kind of situation so I tried to revive my battery by loading it overnight with CTEK charger but it didn't work. Have to go to buy a new battery.
At least E90 needs coding with the new battery, even if the specs remain same. The battery reset will reset the charging etc. settings so the car know to adjust. Going to try that with my INPA and obd-cable. |
11-24-2013, 06:32 AM | #13 | |
Rep 7
Battery
Hi Hiace,
did you solve your battry problem? Quote:
12-30-2013, 02:35 AM | #14 | |
Rep 406
Instagram @luongspec
12-30-2013, 02:53 AM | #15 |
Rep 925
Our oem batteries have life indicator on them I think.
Green = Good Black = needs charge Yellow = replace. I think they call it the "magic eye"? I never paid attention to that when my battery died last month. My angel eyes stopped turning on when I unlocked the car, so thats how I knew it was time to replace. |
