E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Budget Logic 7 delete
      10-27-2013, 02:52 PM   #1
glachhman
Drives: '07 335i e90
Cool Budget Logic 7 delete
Hi guys, recently removed logic 7 and replaced the amplifiers, figured I'd share.
After selling my logic 7 amplifier for 300 locally, I had my car coded to hifi by dj_kevinnn in NYC.
I chose to go with Rockford Fosgate punch amplifiers since they can handle "Balanced Differential Inputs".
- P300X1 ($130) - to power underseats
- P400X4 ($220) - One channel to each of the front speakers, the rear speakers together on the other 2 channels.
- CD changer trim ($71)
I had already purchased two SWS8x slim subs to replace my underseats as one had stopped working. I chose not to purchase the technic harness since I would never revert back to logic 7 & to keep costs down. Not including the cost of the SWS slims I think my cost was around $200. Here are a few pictures.
      10-28-2013, 12:09 AM   #2
_shim
Drives: an e90
looks good
      10-28-2013, 11:35 AM   #3
bmw325i
Drives: 2006 BMW 325i
What did you use instead of Technics harness? I'm assuming you just cut the wires, but how did you get the signal to the amp?
      10-28-2013, 11:40 AM   #4
djkevinnn
Drives: 2008 335i FBO
This is accomplished by getting the Metra quadralock piece and creating RCA outputs for your radio. Then run the RCAs for your amplifier to the trunk.
Also, to prevent getting SOS Errors, you need the MOST terminator loop. Or, if you'd like I can also remove the Logic 7 MOST wires from the loop.
      10-28-2013, 12:13 PM   #5
glachhman
^^ What djkevinnn said, he is the coder & brains behind the setup
      10-28-2013, 12:46 PM   #6
bmw325i
That's what I thought. I had one for sale is why I asked. I've done basically the same thing, although I recently replaced the headunit with an Alpine S920hd. I took the fiber optic wires out of the loop and put them in the unused block since I didn't see a reason to buy the extra parts.
Anyways, did you notice an improvement in sq? You did lose the logic 7 processing but the extra power should clean it up a bit.
      10-28-2013, 01:14 PM   #7
djkevinnn
Definitely an improvement in SQ and power too. The only issue with this is when going to the HIFI stereo, the OEM radio boosts the high frequencies to cope with the lack of tweeters on the HIFI stereo. So with this setup, there is a lot of highs, I personally have my treble at -5 at the moment. At low volumes it's not bad, but at higher volumes it hurts. Maybe down the line a good processor could clean this up.
      10-28-2013, 01:46 PM   #8
bmw325i
Hifi has tweeters, and the signal should be flat. I think the stock logic 7 tweeters are just a little harsh at high volumes.
      10-29-2013, 12:34 PM   #9
J38
BMW Addict
J38's Avatar
11
Drives: '11 X5
Pics are broken for me, what the problem is!
'07 Z4 3.0iS White/Saddle - Sold | '05 330 ZHP Silver/Grey - Sold | '06 330i SGM/Black - Sold | '07 335i Jet Black/Saddle - Sold
Volks are SOLD | '03 330i ZHP Silver/Grey - Sold | '11 X5 35i Sparkling Bronze - Sold
      10-29-2013, 01:25 PM   #10
bmw325i
They work for me.
      10-30-2013, 08:08 AM   #11
J38
BMW Addict
J38's Avatar
11
Drives: '11 X5
They work for me.
Yeah, I probably should have checked the URL before posting. DB is blocked at work. Carry on...
e90post
