N54 cylinder head swap and re-coding injectors
10-16-2013, 07:06 AM | #1 |
Rep 451
Question for the N54 tech' experts on here , anyone swapped heads?
I have been offered a nice low mileage complete cylinder head from a 335i, it comes with everything ready to bolt back on - just as removed from the car. I am tempted to take this and replace my current head which is running fine but at such high mileage (190,000 miles) it might be worth changing over (or just keeping a spare). Will the replacement head be an easy swop, or will things need re-coding to my car? like injectors? |
10-16-2013, 07:25 AM | #2 |
Rep 316
Wow, man. I would love to know everything that's been done to your car repair wise. I have 97K and wonder what the future holds. Sorry, I am not trying to hijack.
10-16-2013, 09:48 AM | #3 | |
Rep 451
Coil packs have been changed a couple of times, water pump once. |
10-16-2013, 09:53 AM | #4 | |
Not Baned
86
Rep 1,353
10-16-2013, 10:30 AM | #5 |
Rep 374
my suggestion is if its not broken, don't fix it. However, keep that head for down the road if you plan to put another 100k on her. Nice job keeping the car up to snuff.
2008 335xi AT
Cobb AP stage 1, drop in filter, the rest stock 13.10@106.01 w/ 1.86 60' (5,800' altitude) |
10-16-2013, 10:36 AM | #6 |
Rep 451
If its a huge job then yes would leave along and keep the spare head somewhere safe just in case.
A 28 hour job sounds a bit crazy to me! But hopefuly someone on here has done before and can confirm one way or the other. I was thinking swapping the head is not much more work than doing a head gasket? How much to do a head gasket on an N54? |
10-16-2013, 12:48 PM | #7 |
Rep 3,953
Easier to remove the motor on that job.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
10-16-2013, 04:06 PM | #8 |
Rep 538
Yes it's a long job to R+R a head. It also requires special tools to locate the cam towers in position since there's no dowels to line them up.
Def not a DIY job. It's almost cheaper to buy a good used engine and swap the whole engine. |
