procede and bov
10-08-2007, 12:44 PM | #1 |
Rep 298
procede and bov
hi mi the only one who read this , i see all this guys talkign about puting bov on the 335, yet at vishnu tuning site you can see
"Q: I am very interested on installing a BOV (Blow-off Valve), is that going to be a problem? A: It is best for one to resist the temptation of installing an aftermarket BOV as our cars were not designed to release excess boost pressure into the atmosphere. Doing so will effect the PROcede’s tuning and cause the car to run poorly. The car was designed to recirculate that excess air back into the intake system. Bleeding off the air that was accounted for by the MAF sensor will confuse everything. " can someone explain this |
10-08-2007, 12:49 PM | #2 |
Rep 5,780
Old information as we do not have a MAF. Albeit, I do recall a post a while back about someone having an issue with the PROcede and an aftermarket BOV. But I sure there are several who have both and have no issues.
10-08-2007, 12:57 PM | #3 |
Rep 1,743
I have been running a BOV and procede since the procede came out for the 335... Everything works fine with no error codes or anything... Now i have the procede and 2 BOV's and everything still works great
10-08-2007, 12:59 PM | #4 |
Rep 114
I think the issues that some people reported were related to boost surge, but then I am not a big fan of aftermarket bov's especially in a road course type of environment.
10-08-2007, 01:09 PM | #5 |
Rep 6,775
Drives: TiAg E92 335
Think about it for a second. The less that someone can mess up under the hood, the less of a headache it is for the guys at vishnu when trying to diagnose problems that may or may not be caused by their product. From their point of view, the less that people run BOVs, the less calls they will get from people saying that something is wrong with their car, which may not even be due to the procede at all, but maybe an incorrectly installed BOV, a vac leak, etc. With that said, many people run BOVs without a problem.
-Michael.
Berlina Black S2000 CR is now in the garage l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l |
10-08-2007, 01:20 PM | #6 |
Rep 10,855
The issue involves the extent to which the plastic diaphram OEM valve can handle the higher boost levels attained with V2. If it can't, then an aftermarket BOV may be a good way to go.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
10-08-2007, 01:37 PM | #8 |
Rep 6,775
Shiv has posted before that he got compressor surge at partial throttle with a tial BOV so he doesn't recommend them. I run a bov, as well as many other members on this forum, and I have never experienced this before. The only way that I can see this happening is if you are running the wrong spring on a tial.
-Michael.
10-08-2007, 11:57 PM | #9 |
Rep 604
I'm kinda new to tuning so if this is a naive question please forgive,...Wound't a new BOV "fix" the limpmode issue with the surge noted by others at the speed limiter and rapid decel from redline in cars running v2?
10-09-2007, 10:48 AM | #10 |
Too many Alex's, from now on, call me Beaufort
342
Rep 6,188
Ive been running the Tial on my car with Procede and no problems. No loss of boost and no surge. Plus it looks pretty when you open the hood.
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip 16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone) 07 335i(gone) |
10-09-2007, 11:15 AM | #11 |
Rep 10,587
I think it may, but like everything else you change on your car it has to be tuned correctly otherwise it will cause MORE problems.
10-09-2007, 11:32 AM | #12 |
Rep 301
The original info from the site was flawed, and I agree with the above posters in regards to insufficient spring pressure on an aftermarket BOV being the root cause of problems.
Kinda OT but I had disconnected the recirc. valves and enjoyed the sound for a while. I then reconnected the valves and noticed a decrease in MPG to the tune of about 20-40miles. Just thought I would share. |
10-09-2007, 12:10 PM | #13 |
Rep 298
i finally got answer yesterday that thing about not runing bov is bullshit its just like somebody said they dont want you to puit on so they wont gte calls that are not related to procede but people may think that are
10-09-2007, 02:12 PM | #14 |
Rep 3,125
Im not much of a fan on the BOV's. But if I do sport one it would be the hks ssqv. But my waste gate would have to be upgraded also.
Previous - E90 335i, E82 135i, E89 Z4 3.5SI, Range Rover S/C, Ultra White RCF, Maserati Granturismo
Current Lexus: SMG LC500 performance package Porsche:1973 911E Ferrari 575 SA, 458 Italia |
10-09-2007, 02:16 PM | #15 |
342
Rep 6,188
Out of curiosity, why would you choose the HKS over all the others?
13 HD FatBob
10-09-2007, 02:23 PM | #16 | |
Rep 3,125
But when the upgraded DV's come out, ill most likey upgrade to that.
10-09-2007, 02:25 PM | #17 | ||
342
Rep 6,188
13 HD FatBob
10-10-2007, 06:07 AM | #18 | |
Rep 5,175
10-10-2007, 07:19 AM | #19 |
Rep 6,775
The difference is probably in the amount of boost that you were running. I had a tial on my turbo s2k and it was pretty quiet since I was only running 7-8psi, but I heard the same BOV on my friends S2K with a headgasket and 12-14psi and it was significantly louder.
-Michael.
10-10-2007, 08:12 AM | #20 | |
342
Rep 6,188
13 HD FatBob
10-10-2007, 09:36 AM | #21 | |
Rep 5,175
10-10-2007, 10:59 AM | #22 |
Rep 6,775
Well, I guess it also has to do with how much more CFM the larger turbo will push at the same psi of boost compared to a smaller turbo. Maybe that amounts to an audible difference?
-Michael.
