How hot is the air coming out of the turbos?
08-27-2013, 02:30 PM | #1 |
Rep 2,136
I found this formula online to calculate the air temperature coming out of a turbocharger:
Tout = Tin + [[Tin x (-1 + (Pout/Pin)^0.263)] / Eff] * Tin = Inlet temperature in °R * Tout = Outlet temperature in °R * Pin = Inlet pressure (psia) * Pout = Outlet pressure (psia) * Eff = turbo efficiency (0 to 1) Assuming an inlet temperature of 80°F and turbo efficiency of 70%, the outlet temperature of the turbo would be: 173°F @ 8psi boost 194°F @ 10psi boost (21°F hotter than stock boost) 211°F @ 12psi boost (38°F hotter than stock boost) 228°F @ 14psi boost (55°F hotter than stock boost) 245°F @ 16psi boost (72°F hotter than stock boost) 260°F @ 18psi boost (87°F hotter than stock boost) 275°F @ 20psi boost (102°F hotter than stock boost) Hence the importance to upgrade the intercooler when running higher than stock boost. These were done with the assumption that the turbos were 70% efficient, and I have no idea if this is correct. Do these numbers look right? Does anyone have actual data on the air temperature before the IC?
JB4 G5 w/ Backend flash - Walbro 450lpfp - VRSF DPs - VRSF 5" stepped IC - DCI - ER CP w/ Tial BOV - 335is clutch |
08-27-2013, 03:56 PM | #3 |
Rep 6,136
Jeff got it right. ETS has some data you might want to check out, but I'm not entirely sure of their accuracy. (scroll down a bit).
http://www.extremeturbosystems.com/E...tercooler.html |
08-27-2013, 04:04 PM | #4 | |
Rep 2,136
