N54 Single Turbo Upgrade ideas?
08-24-2013, 06:41 PM | #1 |
Rep 35
I'm still contemplating the price of the single fftec turbo upgrade and also the power to hp ratio regarding the RB turbos..
I'm not sure if this has been studied or not, but on the N55 forums it seems RB will be coming out with 750hp solutions for the single turbo. Since our blocks are near enough identical, wouldn't the single turbo upgrade from the N55 work on the N54? I'm sure we'd have to change to a 4" single DP fitted for the N55 but hey, I would not mind at all. Just food for though. A cost effective high hp solution! |
08-24-2013, 08:43 PM | #4 |
Rep 288
I believe the flange on Rob's manifold will already be drilled to fit the N54 head. However, I'm not sure if his manifold will allow the O2 sensors to be placed before the turbo (which is currently necessary on the N54).
08-24-2013, 09:29 PM | #5 |
Rep 1,571
The intention of the RB N55 kit is first and foremost to work on the N55. The manifold will be designed with split banks though and will be modeled on the N54 long block we have here. The flange itself is designed to work on both engines. That said it could be used on either engine but some minor fab work maybe needed to work with the N54 (ie. coolant to block interface, etc).
It will not be directly marketed to work with the N54 although someone could certainly weld in pre-turbo O2 bungs and try it- but we will have no part of any backlash of it causing any headaches. The intention is to wait for the bank merger O2 solution to be found before it should be used on the N54, but once it is shipped the end user can do as they like with it. Rob |
08-24-2013, 10:40 PM | #6 | |
Rep 1,392
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust 335i 2009 e90 665RWHP VFF900 ST RIP . |
08-25-2013, 12:37 AM | #7 |
Rep 1,375
I'm sure there's a business stand point reason why he's not doing that. Unfortunately
08-25-2013, 08:59 AM | #8 |
Rep 1,257
My guess would be because it is extra work for a solution that he would have no tuning for. I can't imagine the N55 option being more than plug n play plus a new map for boost, fuel and timing. The N54 variant would have to be test fit and the misc different hardware would have to be made, and then he would have to hope people would buy it without a proven tuning option to recoup his costs. If the single turbo tuning becomes more old hat as people figure it out, then maybe he could revisit the manifold accoutrements down the road. As a small business, Rob needs to be able to see dollars in return for every cent spent if he wants to keep his business going.
08-25-2013, 07:46 PM | #10 | |
Rep 35
I remember back in the day my I6 Trailblazer used one O2 sensor for controlling closed loop. It seemed to work like a charm. With the release of the Open Source program I'm sure there's a way we can get this to work. With regards to the coolant to block line, if using a single we can just cancel the coolant path and rely on the oil tap and intercooler to keep our turbos cool. I would love to get this working as soon as the weather cools down here. We're finally hitting high 20s celsius at night. Hopefully be around 10celsius in 3months! |
08-27-2013, 10:34 AM | #11 | |
Rep 1,571
http://www.e90post.com/forums/showthread.php?t=873417 Rob |
