F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic Maintenance: Wash, Wax, Detailing, Repairs > Dirty Stock Exhaust Tips
ARMA SPEED
      08-23-2013, 09:39 AM   #1
syuan92
Member
syuan92's Avatar
Drives: '20 BMW X3 M40i
I have an ActiveHybrid 3 and when I went to go try and clean the exhaust tips with a paper towel and some water, the black stuff wouldn't come off. Am I suppose to use something more rough than a paper towel? Is there some sort of special chemical that will clean the black stuff off? Will the exhaust tips still be shiny chrome if I use something more rough than a paper towel? Any help would be appreciated!
      08-23-2013, 09:49 AM   #2
syuan92
Member
syuan92's Avatar
Also, I would prefer using common household items as opposed to going out and buying something specifically for just the exhaust tips. I just want to remove the black soot.
      08-23-2013, 12:27 PM   #3
PTek Will
PTek Will's Avatar
Drives: 335i coupe
Steel wool can be used in conjunction with a low grit sand paper. I chose to start with and SOS pad (the kitchen ones, basically soap and steel wool). Which got me to pictures 1 and 2. Which already is a great look from head height.
Size:  40.0 KBName:  2.JPG
Size:  63.1 KBName:  3.JPG
I decided to take it a bit further and used 500 grit sand paper on a drill to get as much of the caked on exhaust dust off as possible.
Next I used a 3" wool pad, that I was ready to toss, combined with M105.
The last step was using the same pad with optimum metal polish (new formula).
Size:  63.6 KBName:  7.JPG
It is pretty blingin lol. If this is too much bling for you, I would say after the steel wool pad just go straight to a metal polish. But just wanted to show that polishing metal is very much like polishing paint, except you can start much more abrassive and work your way up. Using a drill attachment for the sand paper and pc for the compound and polish saved me tons of time and energy. Total work time was under 30 minutes.
Note: There are still very tiny specs of dust that just wont come off. I figure if i went to 500 grit and it still won't come off, then screw it! The finish is so blinding you cannot see it. Hope your project turns out well!
      08-23-2013, 11:46 PM   #4
syuan92
Member
syuan92's Avatar
I gave up on mine. I'm considering just replacing the right tip. I bought my car used with 5k miles on it and I don't think the exhaust tip was ever cleaned so all the soot got baked on.
      08-25-2013, 06:44 AM   #5
Wo-Wo
Wo-Wo's Avatar
Drives: BMW M4 Comp Coupe
The best metal cleaner and sealant on the market is:-
Blue b Gone and its readily available stateside.
http://www.smartwax-usa.com/ProductD...ductCode=40102
      08-26-2013, 02:16 AM   #6
Bradley
Drives: Honda Civic 2006
This product works very well. I mean the exhaust pipe is looking pretty cleaned now, because those cleaning pads remove all the rust from the exhaust pipes. Thanks for sharing that product. I hope this is not too much expensive.
_______________________________________________
Wheelchair lifts For Vehicles
      08-26-2013, 06:15 AM   #7
SamS
Drives: Tesla M3 Perf + '18 X3 M40i
I use my regular car washing soap/water combo + wash mitt, and it comes off every time. Not sure why all the polishing is required
      08-26-2013, 08:28 AM   #8
syuan92
Member
syuan92's Avatar
Should I buy one new tip since there's basically stuff melted all over the right tip and even a thick metal brush can't remove it?
      08-26-2013, 01:25 PM   #9
nilfinite
Drives: F83 M4 & E89 Z4
Ditto, comes off super easily. Try going to one of those self-wash car washes and blasting it with soapy water.
      06-09-2015, 06:51 PM   #10
Kabrich
Drives: '13 AH3 (335IH) 3F93 MSport
Instructions on the site say to clean area well before application.
That is what OP is trying to get to - something to cut the carbon build up.
      06-09-2015, 11:50 PM   #11
Aaaaaaaaa
Drives: The other M3
      06-09-2015, 11:51 PM   #12
Aaaaaaaaa
Also, please don't tell us you wash your car by wiping it with wet paper towels.
      06-10-2015, 11:05 PM   #13
Kabrich
One would think there should be something simple for this as a spray on and rinse off to cut through the carbon build up.
Then the Chrome could be treated as one saw fit (polish or sandpaper etc)
      06-11-2015, 08:30 AM   #14
smithf80
smithf80's Avatar
Drives: G80 M3 6MT
2022 G20 330i  [9.00]
2018 F80 M3  [9.75]
I use this, I love it.
http://www.amazon.com/BlueMagic-400-.../dp/B000BO8Z9I
      06-11-2015, 08:54 AM   #15
chazmink
chazmink's Avatar
Drives: 2013 328i M Sport
A simple solution is to just use aluminum foil. Works great.
Best,
Charlie
2013 328i MSport Estoril Blue, 6spd MT, Premium, Tech & Drivers Assist +, Bavsound Stage One/Ghost, Bimmertech Amp
      06-11-2015, 09:44 AM   #16
n55x3
Drives: n55 BMWs
000 Steel wool and water, cheap and effective.
      06-11-2015, 10:14 AM   #17
Professor///M
Professor///M's Avatar
Drives: 2022 M3, 2022 X5 40i;
On a routine basis you can use Simple Green. Generally what I did with my e90 is a quick spray on a rag dedicated to the exhaust tips after every return back to the garage. That kept them clean.
When they got bad, or during winter when I didn't do this daily, I used simple green along with a minimally abrasive sponge.
You could even use 00 steel wool.
There are also metal polishes that if those don't do the trick, will get that buildup right off.
      06-11-2015, 03:25 PM   #18
vanbmw
vanbmw's Avatar
Drives: 2015 Black 335i
I use optimum meal polish. They say you can use 000 steel wool with it but I haven't had to. I just wipe it on with a cloth, let it dry and buff it with microfiber. Looks great. Any black that builds up on it will wipe off easily now. I reapply the metal polish every month or 2. Takes 2 minutes and looks great.
      06-11-2015, 05:38 PM   #19
CaliCanadian
Drives: 2012 A4 / 2015 Alpina B6
Do the exhaust tips come off? Spent 20 minutes using Never Dull or whatever but it had to effect on the stuff that was really crusted on. Found out that I can remove the exhaust tips, took it to my laundry room, found some metal scrubbing thing used for stainless steel appliances, and it had my exhaust tips looking practically new in 5 minutes.
The metal scrubbing pad I'm referring to is this: http://www.amazon.com/gp/product/B00...1AYNB9W2SC67EQ
not the exact one but yea you should be able to find it anywhere.
OH and be very careful if the exhaust tips cannot be removed while using steel wool or metal scrubbing pads, it will destroy the paint on your car or anything that's plastic or whatever.
      06-17-2015, 10:19 AM   #20
CharlieVu
Drives: 2013 328i x-drive Melbourn RED
Exhaust- NVR DULL and Chrome polish
I used a combination of products.
Carb Cleaner to Wet a Soft wool
Nvr Dull
and Chrome Polish
Charlie Vu
2013 328iX Melb RED- JB4 - AFE 5R Intake - B14 Bilstein - Morimoto H1 Projectors and LED Angel eyes- Morimoto HD Elite 50w 5500k H.I.D.
      06-17-2015, 10:43 AM   #21
vanbmw
vanbmw's Avatar
Nice work Charlie! Huge improvement
      06-25-2015, 01:13 PM   #22
K_Ifti
Drives: F31 335d M Sport
Looks good. My first post on the forum. I'm back to BMW with a bang!!
f30post
