08-08-2013, 07:59 PM | #1 |
Rep 157
BMS Tune - N63 Stage 1
Has anyone tried this? Looks pretty interesting, but it appears Terry hasn't sold a lot of these to the F10 M5 folk. Single map at the moment, looks like it increases boost by 2.25 PSI.
http://www.burgertuning.com/N63_Jb_B...nce_Tuner.html With that said, I have a feeling we could get more then 25 HP / 40 Torque - considering those dyno sheets are from a 750i. |
08-08-2013, 08:24 PM | #2 | |
Rep 1,489
I have also read that the switzer piggyback is running between +5/6 PSI. I do not have solid "apples to apples" data on that, but I have seen the burger data logs (taken from the TMAP sensor, directly from the piggyback module) and data provided by a Switzer owner (off of a P3car gauge) and that looks to be about right.
Current: '16 GT4
Past ///Ms: '13 F10 M5, Alpine Weiss III/Sakhir Orange Full '10 E60 M5, Space Gray/Black |
08-08-2013, 08:40 PM | #3 |
Rep 157
From the looks of it, we'll need some sort of "black box" (manhart, switzer) in order to get more boost. Does the +5/6 PSI include Switzer's "Engine Control Module", or is that just from the tune?
08-08-2013, 08:53 PM | #4 | |
Rep 1,489
The BMS tune is similar, along with Hartge. I have not seen the Manhart boost box but I'd assume it is similar as well. Could be wrong though. I have not seen any OBDII data from a car with the Hartge piggyback or the Manhart boxes - plus, the Manhart boost boxes are only on their upper stage for the M5. So, you are adding that on top of the OBDII flash.
Current: '16 GT4
08-08-2013, 10:36 PM | #5 |
Rep 157
I think out of all the tunes then, this might be the best choice for the price then. It's not like the tuner detection codes is going to matter at this point, considering all other systems involve something similar (piggyback), or a ECU flash (super obvious).
Looking at the price, this unit may eventually sell enough for a Stage II (around ~250 units), which might actually have multiple maps ... seems like the more viable option in the long-run. Best part is, it's essentially a plug and play, we don't even have to splice wires. |
08-09-2013, 11:50 PM | #6 |
Rep 785
FWIW I've had a JB4 piggyback on my 135i for 3.5 years now. It's been pretty solid. Frequent updates and great support from Terry whenever you need it.
I'm tempted to try this on the M5. Run some logs and send them to Terry for good measure, and receive a clean bill of health before romping on it. He said near 40hp give or take depending on conditions, and should be fine with other mods like downpipes. Also mentioned he had not heard of any codes being thrown. I was thinking: -BMS tune and Can Bus Cable to clear codes: 25 to 40whp $500 - AMS Down Pipes (Catless) 30 to 40whp $1800 - K&N drop ins -5whp lol $100 So for under $2500 you've got an extra 60 to 80 or so HP. If stock cars are making over 600 crank hp, this should nudge you close to the 700 mark. Not bad...
991 Turbo
993 GT2 Outlaw |
08-10-2013, 05:48 AM | #7 |
Rep 657
I have one including the USB cable not fitted it yet. 2.25 psi seemed a bit tame so was going to do some runs @ 2.25 then up it to 4 psi and do some more to see how it performs.
Not sure I want an extra 6psi until I do a bit of playing.
540i
GTR-R35, F90 M5, X3MC, RS3, RS7, M5, S7, S3, RS3, RS6, GTR R35, 996 Turbo, M5, RS6 V10, Cayenne Turbo S |
08-10-2013, 07:40 AM | #8 |
Rep 785
08-11-2013, 09:49 AM | #9 |
Rep 405
I have it on my M5, Like M5 TT said 2.225 is a bit tame for the s63tu. So I have it at plus 3.00 boost over stock. I will do a full review with dyno etc sometime midweek, But this thing def works great so far
08-11-2013, 06:02 PM | #10 | |
Rep 1,489
Right on. So no issues at +3! Good stuff. I am assuming that Terry has looked at your data logs?
Current: '16 GT4
08-11-2013, 07:13 PM | #11 |
Rep 2,176
Guys I can't believe people are being so cavalier about tricking the ECU to run more boost on the S63tu. It already runs at 22psi vs 17in the S63 with a 10.1 vs 9.1 compression ratio. BMW obviously tuned the S63tu to make similar power as the S63 with less fuel consumption . Until the ECU is cracked all these piggyback solutions are adding is tons of extra heat , with a little power for maybe 1-2 pulls . This is best case as in the Manhart stage 4 as it also has an ECU tune . To just up the boost without changing the ECU by more than maybe 1 psi could be disastrous and will be minimally effective. Be patient real tunes will come . But running a setup not even designed for the S63tu is just stupid .
08-11-2013, 08:03 PM | #12 |
Rep 13
Is it confirmed that our cars run up to 22 PSI stock? I've got a P3/Turner gauge and the most boost I've ever seen is 17.4 PSI.
Just curious if I what I am seeing is normal or my boost (or gauge) is off... Sorry to get a bit off topic. |
08-11-2013, 09:00 PM | #13 | |
Rep 646
08-11-2013, 09:47 PM | #14 | |
Rep 2,176
S63Tü (F10 M5)* S63 (X5/6 M) Engine Configuration/No of cyls/valves V / 8 / 4 V / 8 / 4 Engine technology M TwinPower Turbo technology with cross-bank exhaust manifold, twin-scroll turbocharging, direct petrol injection, (High Precision Injection), VALVETRONIC and Double-Vanos M TwinPower Turbo with exhaust gas manifold connecting both rows of cylinders. Twin Scroll Twin Turbo technology. High Precision Injection. double-VANOS Effective capacity 4395 ccm 4395 ccm Bore 88.3 mm 88.3 mm Stroke 89.0 mm 89.0 mm Compression ratio 10.0:1 9.3:1 Maximum Boost Pressure (absolute) 1.5 bar 1.2 bar Output 560hp 555hp @ 5,750 – 7,000 rpm 6,000 rpm Torque 501 lb-ft 501 lb-ft @ 1,500 – 5,750 rpm 1,500 – 5,650 rpm Redline 7,200rpm 7,000rpm * Tü is German and stands for 'Technische Überholung' which translates to 'technical revision' |
08-11-2013, 10:02 PM | #15 |
Rep 13
Hmm...OK, well I'll make a couple more runs and see what the peak boost is. Does anyone else have a boost gauge?
It may be nothing, but it does seem a little odd that the peak boost I've seen has been 1.2 bar...which matches up with the quoted peak boost of the X5M/X6M. Thanks, Tom |
08-11-2013, 10:23 PM | #16 | |
Rep 157
08-11-2013, 10:28 PM | #17 | |
Rep 1,341
Drives: 2013 M5 SSII
08-11-2013, 10:34 PM | #18 |
Rep 157
Seems like the same results as this thread.. http://f10.m5post.com/forums/showthr...ghlight=p3cars
08-12-2013, 05:35 AM | #19 |
Rep 657
But is it not the case the ecu will give up to1.5 bar of boost to achieve 560bhp?
At sea level 1.2 bar of boost is enough for 560. Drive into the mountains where air is thinner 1.2 bar of boost won't be enough or in very hot humid countries again 1.2 bar won't be enough to make 560 so the ecu will give more boost to attain the required amount of torque Is there an obd reader I can buy that will log boost I will see what mine is doing? I am sure there is just not looked into it yet
540i
08-12-2013, 05:55 AM | #20 | ||
Rep 2,176
08-12-2013, 10:01 AM | #21 | |
Rep 157
08-12-2013, 01:17 PM | #22 |
Rep 2,176
I agree it is odd, and admit the problem with the P3 gauge boost readings on the Z4M was the included Boost monitoring tap. It should be able to get good sampling data from the ECU from the OBD on a car that is monitoring it live but it may be a problem with the sampling rate.
