F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > 4 Series M-Performance LSD
Extreme Powerhouse
      07-18-2013, 09:29 PM   #1
nsquared
[Versatile]
nsquared's Avatar
378
Drives: (S)LOW.
As some have already read, the 4 series will have the option of a LSD (Limited-Slip Differential) as an option from the M-Performance Catalog. Do you think they will offer a LSD option for the 3 series?
I also wonder how much it will run considering its mechanical. I'm sure it will be more than the M-Performance Brakes?
'02 TS E46 330xi - SOLD
'06 SGM E90 325i - SOLD
'13 AW F30 335i ///M-Sport 6MT. OEM(+) - SOLD
'20 AW F87 X3MC - Sold
Current: `23 Chalk G80 M3CX | Ordered: '24 M3CS - Week37 build.
      07-18-2013, 10:20 PM   #2
RSXDC5
RSXDC5's Avatar
707
Drives: M3
The 4 series and 3 series should have the same rear end...for the 335i/435i at least...
Now we just need to figure out if the 328i and 335i have the same rear ends! Does anyone know?
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs
      07-18-2013, 10:51 PM   #3
M.Suka
M.Suka's Avatar
Drives: 2013 335i M Sport
For autos they are the same part numbers for 328i and 335i, part number 33107603749.
European delivery 9-19-2012
      07-18-2013, 11:19 PM   #4
ronin951
ronin951's Avatar
44
Drives: 2013 328i M-Sport
According to realoem it's the same for auto/manuals. I'm not sure why you made the distinction, so feel free to correct me.
      07-18-2013, 11:21 PM   #5
RSXDC5
RSXDC5's Avatar
707
Drives: M3
This is good news though, this means we should be able to use the 4-series differential
      07-19-2013, 01:04 AM   #6
M.Suka
M.Suka's Avatar
Manuals have a different part number but I'm sure they will release for auto as well as manual.
      07-19-2013, 04:25 PM   #7
RSXDC5
RSXDC5's Avatar
707
Drives: M3
Hey at least we get a factory differential now! This car needs one SOOOO SOOOO freaking bad
      07-19-2013, 05:59 PM   #8
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
I'm sure we'll get an M Peformance variant soon for the rear diffs...My car needs one desperately, I for one will be eagerly awaiting this!!
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray
M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com
      07-19-2013, 08:53 PM   #9
nsquared
[Versatile]
nsquared's Avatar
378
Drives: (S)LOW.
I can't wait. Hopefully it doesn't destroy the wallet lol.
      07-20-2013, 07:13 AM   #10
shivaswrath
Drives: 2012 335i
it'll probably be $2k installed minimum...
      07-20-2013, 10:53 AM   #11
utenigma
Drives: 2013 F30 335i 8SA M-Adaptive
Ha! It'll be more than twice that much. 5k is my guess
      07-20-2013, 11:31 AM   #12
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
I'd guess $5k installed. I'm pretty sure I read that our diff isn't easily accessible... Will need cutting/machining
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      07-20-2013, 02:17 PM   #13
oceanview
oceanview's Avatar
Switzerland
207
Drives: 335i F31 RWD Autom.
In this thread:
http://www.f30post.com/forums/showthread.php?t=858575
download the "02_F30 Powertrain.pdf"
on chapter 7.1, 7.2 and 8.2.1 are some informations about the differential variants.
Looks like you said.
328i and 335i (automatic) have the same.
328i (Manual) has the same but with another gear ratio
335i (Manual) has a different one also different gear ratio
That's gonna be an expensive after market upgrade
Just saw, the part number you listed sells for about $ 1700 plus labour. (And LSD will sure be more expensive than the original diff.
I wonder if the software of DSC/DTC also needs to be changed?
(With LSD you need to have wheelspin on one wheel to get the other wheel turned.)
      07-20-2013, 03:58 PM   #14
shivaswrath
Drives: 2012 335i
Originally Posted by tojo_m View Post
Audi S4's LSD is about $1500 upgrade (at factory)
that's why I was figuring about $2k.
$5k no one would do, so trust me, they wouldn't even offer it.
      07-20-2013, 04:36 PM   #15
mikew2069
mikew2069's Avatar
413
I could see $3k as a factory option but not after the fact
      07-20-2013, 09:38 PM   #16
ronin951
ronin951's Avatar
44
I couldn't see it being anything but a factory option. I can't imagine dealerships doing any kind of machining. I just don't think the tooling and/or training is going to be there.
Personally I'm going to sit on the sidelines for an F30 version of http://store.vacmotorsports.com/vac-...als-p2324.aspx . Maybe if enough of us call they'll do the R&D
I've had http://www.e90post.com/forums/showthread.php?t=365404 bookmarked for a while. It's missing some pics, but a very good writeup. This guy did his research and concluded Quaife.
      07-21-2013, 02:48 AM   #17
buildbright
buildbright's Avatar
155
Drives: F80 M3 MG
Sure they would the M Performance Wheels MSRP for $4750 and that's just for wheels.
      07-21-2013, 07:23 AM   #18
mikew2069
mikew2069's Avatar
413
Quaife is the shit... According to the link you provided, It looks like $4k total at a good shop.
BM3/H&R/Borla
      07-29-2013, 05:13 PM   #19
utenigma
I would hope you would order the diff with the right ring gear attached - and turn in your old for a core charge. That's the only way I can imagine that BMW would make it available after market - there's no way the average dealer could machine off the ring gear and tap it for bolts like the wavetrac guys do
      08-04-2013, 11:22 PM   #20
jamesems
Drives: 2013 335i msport f30
you know whats funny...I'd consider 4k...but 5k hell no...perception is a bitch
      08-08-2013, 09:15 AM   #21
DVC
Diligentia Vis Celeritas
DVC's Avatar
Drives: 335i
I will definitely be picking up an LSD as one of my first mods... was looking at Wavetrac or Quaife, but if there's a *reasonably priced* M Perf option, then that would be the way to go. (No warranty issues, etc.)
I wonder how long until they make it available though - I was hoping to get one installed before the end of the year
Ahead of the curve for specF30
      08-08-2013, 12:16 PM   #22
shivaswrath
Drives: 2012 335i
Cost pricing for those wheels is about $3800 or so, I think my dealer and a few on ebay were pricing as such.
Most owners of the 335i are mildy inelastic up until about $5000. That's why they offered the MPPK WITH a DME (a new DME costs about $3900 according to my dealer) for $899 at cost, or about $1299 MSRP.
f30post
