07-15-2013, 08:18 PM | #1 |
Rep 1,349
Drives: 330i
F30 Mud Flaps Retrofit Kit PDF
I just received this file today.
Front installation is required only to rotate tires to open space. Rear - tire off only options.
'06 330i Monaco Blue/Gray/Walnut/ZPP/Navi/CA/AT -->ED 2006
'18 330i Estoril Blue Metallic/cognac/AT/Sport |
08-01-2013, 04:32 PM | #2 |
Rep 312
Looks like it should be pretty easy but I wonder if English to American translation is still required. One page refers to a lug being formed (but isn't talking about a wheel). Elsewhere, expanding rivets are removed. I've worked with expanding rivets on aircraft before and they had to be drilled out yet the instructions call for them to be unscrewed. Are they speaking of something like a wall anchor perhaps?
Have your completed your installation yet? How did it go? |
stroker1562.50 |
08-02-2013, 10:52 AM | #3 | |
Rep 1,349
Drives: 330i
Rivets is plastic and hold in place by plastic pin (about 1mm diameter) inside. You take a screwdriver or something else sharp and push this inside pin more inside and it will go. And then you will be able remove rivets. Install is the same you install rivets first (they came with this pin sticking up) and then use small hammer to push inside pin to the rivets head. I will made a few pics, when I get home from work.
stroker1562.50 |
08-04-2013, 01:22 PM | #4 |
Rep 1,349
Drives: 330i
I don't have new rivets, so I used old one (previously used, that you will removed during installation). Instead of nail it will be a plastic pin.
To remove pin, you have to tip with sharp object on the pin (pic 3) end pin will go inside and relive rivets. New rivets with pin looks like one on Pic 2. You replaced one with new and with small hummer push pin till he seat with the level of rivets head (pic 3)
'18 330i Estoril Blue Metallic/cognac/AT/Sport Last edited by MB330; 08-04-2013 at 01:31 PM.. |
stroker1562.50 |
02-18-2014, 08:27 AM | #6 |
Rep 1,003
Drives: 16 340i, 15 X3d, 91 318i
Has anyone done this and can comment on the adhesive "seal" that goes against the body? I'm tackling this soon and initially was planning on only running the flaps during winter months, so I'm wondering if the adhesive can be removed from the flaps and a 3M double-stick type solution used after the first use.
stroker1562.50 |
02-18-2014, 01:51 PM | #7 | |
Rep 34
The "seal" is a very narrow bit of double-sided sticky foam-type tape. I think it's probably meant to fill any small gaps so that water/grit doesn't creep behind the flap and onto the paintwork. I can't see why you couldn't just pull of the mudflaps if you really wanted to-I doubt the tape would have a very strong hold. I did not have to remove the rear wheels to get the mudflaps fitted, either... there was sufficient room to use a small socket on the heads of the bolts. |
stroker1562.50 |
02-18-2014, 02:01 PM | #8 | |
Rep 1,003
stroker1562.50 |
01-04-2017, 09:35 PM | #9 | |
Rep 906
Does anyone know if BMW makes mudflaps for LCI cars?
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World |
01-05-2017, 06:15 AM | #10 |
Rep 1,924
wish I had seen this tip for not taking the backing off the mudflaps adhesive tape BEFORE I fitted mine!!
I just fitted a set to a F31 Msport....fitted fine. UK car so wonder if there is a difference? |
01-05-2017, 09:28 AM | #11 |
Rep 906
Is your F31 is a newer car? Do you have the part number for the fronts? Mine is 82 16 2 218 983
01-05-2017, 10:04 PM | #12 | |
Rep 2,194
For vehicles with M Sports package and M Aerodynamics package 01 Set mud flaps, front F30/F31 82162218983 02 Set mud flaps, rear F30/F31 82162218984 http://www.realoem.com/bmw/enUS/part...%0982162218983
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining |
JDAURIA725.00 |
01-06-2017, 06:28 AM | #13 |
Rep 1,924
I ordered off Amazon - hope this works
BMW Genuine Mud Flaps Guards Set Rear F30/F31 3 Series (82 16 2 218 984) https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1 BMW Genuine Mud Flaps Guards Set Front F30/F31 3 Series (82 16 2 218 983) https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1 |
01-06-2017, 06:29 AM | #14 |
Rep 1,924
01-06-2017, 10:47 PM | #15 | ||
Rep 906
01-07-2017, 01:46 AM | #16 |
Rep 1,924
01-07-2017, 06:55 PM | #17 | |
Rep 906
2020 i3 Rex: Capparis White, Giga World Last edited by capt_slow; 01-11-2022 at 12:57 AM.. Reason: Fixed broken image links |
