Vargas Stage 2 update DYNO/track Day
07-10-2013, 01:21 PM | #1 |
Rep 689
Drives: 335i Coupe M-Sport Lemans blue
Well at the Behest of Tony I am posting some new info here for everyone. I should have been more on top of this but have had a lot going on that has kept me far to busy to be posting non stop updates so here it goes.
Car: Vargas Stage 2 turbos with upgraded thrust parts VRSF 7" FMIC Vargas upgraded HPFP Standalone Walbro 450LPH e85 pump BMS Catless downpipes (thermal coated in & out) BMS DCI BMS OCC BMS oil thermostat mod RB Turbo PCV fix Quaife LSD 6AT with Alpina Flash Stock catback exhaust Stock 193m wheels with 255/40 conti sport contact 3's Stock charge pipe No Meth JB4 G4 board hooked up for canflap/gauge hijacking/quick logging(no tuning use currently) Cobb AP Protune by Dzenno@ptf Car is currently tuned for E50 and peak boost of 20PSI tapering to 18 at redline with max timing advance around 14 degrees (need to verify, sorry so many tune revisions I sometimes forget) To preface the following info. The dyno is a Mustang dyno, it does not read high. We have personally verified this in the past by dynoing one of our cars on back to back days, first at sound performance on the mustang and the next day in same weather conditions at a different mustang which read even higher. The pull was done during a dyno day open house, I unfortunately only got one good pull in as they asked my buddy and I to jump on unplanned just to add a few cars to the list for the day. We got the one pull in, and afterward the shop crew got tied up taking care of something for about 10 minutes and left my car idling on the dyno when we did the second pull the guy smashed the gas and hit kickdown ruining the pull, and by the third it was so heat soaked it wasn't worth saving the run. I spun in 4th a little bit and the car pulled a couple of pounds of boost and some timing but still made 483rwhp It is the only place my car has ever dynod. They were as follows First time(sep 12) JB4 only 30%e85mix 386whp map 5 second time(feb 12) added downpipes dyno in map 2 on only 93 octane 338whp Dyno again in map 4(stock map) 297whp which is spot on for stock map with downpipes Third time(jun 12) FBO as listed above 50% e85 483whp So on this same dyno I have a 186WHP delta from my baseline of stock map+catlessdownpipes SKIP TO 5:51 TO SEE ME DYNO direct time links dont work Also got out to the track recently, I was running on the stock wheels with 255 width summer tires. Car ran in the 11's all day with 4 of my 6 passes in the 11.80's Ambient temperature was 79-84 most of the day with track temps near 100 and humidity of about 70% I asked this caliber for a money race... he declined. We ended up lining up together by chance lol
2009 E92 M-Sport 6AT PTF Pro Tune Vargas Stage 2
07-10-2013, 01:45 PM | #2 |
2095
Rep 43,350
Nice numbers! Any interest in swapping your current 7" for the newest generation? A bit less pressure drop and a couple extra cooling rows should help you a bit.
07-10-2013, 01:53 PM | #4 |
Rep 69
Drives: 2008 335XI
Please get it on a dynojet! Your probably gonna make around 520!
07-10-2013, 02:08 PM | #6 |
NeedsMoarBoost
42
Rep 527
if that was the case his trap would be much higher, even in a 2000 DA
08 135i 6m - 12.1@120.2 2.0 60ft - JB4/Meth - SOLD
09 335i e92 Mtech - RB FBO |
07-10-2013, 02:11 PM | #8 |
NeedsMoarBoost
42
Rep 527
at 2350 DA Dragtimes calculator shows these corrections on july 1 at tri county track which is just one random track i picked in IL on the 1st of July
Stock and Mildly Modified Naturally Aspirated Engines 11.468 @ 122.917 MPH Extensively Modified Naturally Aspirated Engines 11.581 @ 121.761 MPH Extensively Modified Supercharged and Turbocharged Engines 11.676 @ 120.642 MPH
07-10-2013, 02:37 PM | #9 |
Rep 1,079
Where can I find more info on this?
2004 E46 M3 | Imola Red on Cinnamon | Slicktop | Manual Seats | 6spd MT |
07-10-2013, 03:09 PM | #10 |
Rep 1,185
07-10-2013, 03:45 PM | #11 |
Rep 1,177
Honest question (not trolling/flaming)...
How much better is this than the stock turbos with the same mods, octane, and E85 mix ? I thought there were stock turbo FBO cars with E85 well into the low-mid 400 WHP ? |
07-10-2013, 03:59 PM | #12 | |
Rep 1,185
Same goes with RB turbos. We spent $500 for our first 100hp, then $2500 for the other? Thats seems wrong if you ask me. If it was me, I'd rather pay someone to custom build me a Single turbo setup with a monster turbo for 5k-6k and get well over 600rhwp. Then if the turbo is big enough you can get the rest of the supporting mods and break into the 700+ range. So far I've only seen a few threads of people attempting it. Seems promising and seems like the new way to go. All it takes is mass producing this monster. Now this is a way better way to spend your thousands!! I love the top mount idea! Seems perfect for cheap install of turbo upgrades, rebuilds ect... Although for someone living in CA this might not be a good idea since you wont pass smog (Legally). If the top mount gets into a kit or i decided to have one custom made I'll be doing it since I'm moving to Florida next year. I hate CA laws with cars! Cant even change your air filter without failing (unless its a $300 carb sticker one). Its so Sad http://www.e90post.com/forums/showth...p+single+turbo http://www.e90post.com/forums/showth...m+single+turbo |
07-10-2013, 04:24 PM | #13 |
Rep 3,004
NICE NUMBERS on a Mustang Dyno...It would be great to see some numbers on a DynoJet, I am sure you will be well over 500WHP.
2007 E92 6MT SGM: MusicarNW Level 2, Procede Rev 2.5, FFTEC/Vishnu LPFP with Flexfuel Sensor and Flash, M3 Offset V701's, WaveTrac LSD, Michelin PSS, Downpipes, M3 Control Arms, TCKline D/A Suspension, LCI Tail lights, Lux AE's, ER Charge Pipe, DCI's, Mtech Front and Rear, M3 Sideskirts, HPF Stage 1 Clutch
07-10-2013, 04:39 PM | #14 | |
Rep 1,185
Looks like the duel rollers are the True mustang Dynos since they do full load on the car and the Singles are Inertia only. I'm not really sure how that would affect dyno numbers. Anyone who owns one able to explain this more? I bet if he had that big fan (behind his car in the video) on his radiator he would have pulled a little bit higher numbers. http://www.mustangdyne.com/mustangdy...aster%20Series http://www.mustangdyne.com/mustangdy...D-800%20Series |
07-10-2013, 04:46 PM | #15 | |
Rep 1,708
RBs have performed great trapping roughly 5mph over stock… this is a substantial gain putting you in c6z territory and keeping stockish drivability. Pretty good for $3k. **Lurkers considering an n54, please see below link of car ready for these RBs (or rev2 VVT) I speak of…** |
07-10-2013, 05:14 PM | #16 |
Rep 1,909
Nice!
Current: 2017 F30 340i xdrive
Previous: 2008 e92 335i coupe: RB turbos, mach 116 race fuel, methanol, alot of boost. Previous: 2003 Honda Accord V6 coupe: AEM V2, zex 75 wet shot (sold) |
07-10-2013, 05:57 PM | #17 | ||
Rep 2,682
07-10-2013, 05:57 PM | #18 |
Rep 783
These are amazing numbers. What people seem to always forget about is how stock turbos lose power towards redline compared to these and RB turbos. I am starting to really like these Stage 2 units. Decisions decisions.
'07 335i E90 - PTF ProTUNED by Dzenno - COBB FMIC - AFE DCI - AA DPs - HFS4 Meth
'09 M3 - Stock |
07-10-2013, 06:42 PM | #19 |
Rep 1,708
07-10-2013, 08:20 PM | #20 |
Rep 6,631
Not trying to be a debbie downer, but even after factoring in for DA a 119 MPH trap is pretty bad. I trapped 122.5 on RBs in +1100 DA at 19 psi on E85 running next to no timing due to 6AT post-shift correction issues.
Considering you're running cobb-only, I think you probably had the same timing correction issues. Any datalogs of your quarter mile runs?
E90 LCI N54 6AT
07-10-2013, 08:24 PM | #21 | |
Reborn
84
Rep 1,217
Thanks for posting results OP! You're holding a good amount of boost compared to the stock turbos. |
07-10-2013, 08:39 PM | #22 |
242
Rep 2,781
Drives: E90 335i Racecar
Great numbers! GIAC called me today and said they just broke through with some good power, no numbers yet though, just teasing me.
HG Motorsports | Motiv Motorsport | Sparta Evolution | BBS Motorsports | Sabelt | JRZ | NASA ST1 SoCal --- 554whp/487wtrq --- 3200lbs <<YouTube Channel w/ Race Videos>> |
