first JB4 Log - is boost leak fixed ?
07-09-2013, 11:44 PM | #1 |
Rep 1,909
MAx boost I saw is 13... Duty cycle of turbo's high ? How to read this to determine if I still have a boost leak - No codes, I couldn't do many WOTs
07-09-2013, 11:47 PM | #2 |
Rep 1,909
also idle RPM when oil at 240 jumps to 800 - 825, cold car (after warm up) is 600 .. Is this due to fan ? AC was kept off
07-11-2013, 10:14 PM | #4 |
Rep 725
has to be wot in 3rd 2500-6200 or so in order to give you informed info
ptf MHD E85 /Hexon rr550 turbo's/PRE custom intakes/CP / bms dp's/hfs4 / er fmic/PSS/spec stage 2+/kwv2/steveAZ stage 3 lpfp /m3 control arms/powerflex black/MF LSD /fuel it port injection
07-12-2013, 10:02 AM | #5 |
3441
Rep 79,211
^ Like he said you NEED to be wide open throttle the entire time from 2500 RPM To redline in preferbly 3rd gear with traction control completely off. (That's holding the traction control button for 3+ seconds).
You don't need to make another thread just post a new log here. |
07-13-2013, 12:29 AM | #7 |
Rep 725
does not look good ....
07-13-2013, 09:36 AM | #8 |
Rep 1,909
Can someone explain whats wrong with that graph .... I see the boost isn't climbing up till abt 4k RPM & goes upto only 15 psi ... target was asking 14 since 2k RPM ........
I checked DME codes, it had the Overboost code CEL on (butI didnt get any CEL..., JB4 auto-delete is disabled) ... whats going on the PWM came down to 28 or something is that normal ? |
07-13-2013, 08:51 PM | #9 |
Rep 1,909
I found severe air leak from the rear turbo inlet hose
#10 in the pic http://www.realoem.com/bmw/showparts...84&hg=13&fg=20 I bought this rubber seal but its funny it doesnt have a clamp its just snap on WTF was bmw engs thinking ? .. looks like I gotta take the downpipes out to install it, that gonna be a pain |
09-20-2013, 07:24 PM | #10 | |
Rep 132
09-23-2013, 02:34 PM | #11 |
Rep 1,909
