Finally car sorted, but worrying oil on spark plugs
07-08-2013, 11:44 AM | #1 |
Senior Troll
224
Rep 3,378
So after changing
HPFP Low pressure fuel sensor vano's Solenoids and 6 x new spark plugs and one Coil pack on cylinder 4. Finally the car is back to healthy. No more rough idle,weak start up etc My mechanic gave me back my old spark plugs , 4 of them looks to be good condition and 2 of them have lots of carbon build up and oil residue on the plug thread! plugs are 30k tuned miles and lasted a 5000km europe trip. did i change some too early? should i worry about anything? what do you guys think this is? leaky injectors?? or oil gasket is leaking oil onto it?? I think its most likely its a leaking oil gastket on the top of the engine sipping oil onto the plug? cheers for any input
Gone:
N54 335i is the Legend! N55 435i Now: 718 Cayman GTS / F83 M4 Last edited by AlanYoro35i; 07-08-2013 at 11:50 AM.. |
07-08-2013, 12:11 PM | #3 |
Rep 7,690
Drives: 335i SE Coupe Space Grey
they look fooked! mine ones were "cleaner" and it looks like mine is running lean.
07-08-2013, 12:17 PM | #4 | |
Senior Troll
224
Rep 3,378
you will know when you change next time haha
Gone:
N54 335i is the Legend! N55 435i Now: 718 Cayman GTS / F83 M4 |
07-08-2013, 12:28 PM | #5 |
Senior Troll
224
Rep 3,378
Dammn, now thats not good to hear.. lets see what other guys think first..
Gone:
07-08-2013, 02:25 PM | #7 |
Senior Troll
224
Rep 3,378
Damn..now i need to put the cobb back on to see if there is anymore problem.
I duno how to find which injector needs replacing now =(
Gone:
07-08-2013, 02:30 PM | #8 |
Rep 3,194
Drives: E92 325i MSport Coupe
Take your plugs out one by one (yes, the new ones will already be black) to see which cylinders are running rich.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
