few questions before rb's turbo upgrade
07-08-2013, 08:23 AM | #1 |
Rep 589
My car 335 e92 2007 automatic
Jb4 Aa dp Injen dci Forge dv' Akrapovic Aa intercooler 90k km We have here (israel) 98 octane fuel which is premium I believe it's like 95 at the state.... I don't want meth, or i just don't know what is the benefit / problems.... Last Dyno I pull out 365 bhp on map 5 but i have misfire at higher revs so i stopped it , the guy said to me it will need to pass over the 370 easy My turbos start to rattle badly I don't track my car I want minimum problems looking for safe and strong but daily car I know I need to order the Cobb for tuning although i don't know why? its another 900$ with the g5 But beside that what else i need to order? I wanna know where I'm going and how much it will be I'm looking for safe Hp without to deal with at' gear problem thanks for the help here is the dyno file
2008 e92 335 FBO
2011 e92 M3 ZCP DCT 2015 f82 M4 DCT |
07-08-2013, 09:03 AM | #2 |
Rep 3,262
Yes you will get some more power with the RB turbos with standard 98RON fuel (equivalent to 93 octane US), but mostly after 5000RPM and not more than 15-20whp peak numbers, if you stick with a "safe" boost like 18.5psi midrange to 14 at redline. However the power band will be a lot better after 5000-5500RPM.
You will also get some more lag. You do need Cobb or other ECU flash solution if you don't want to ruin your engine. JB4 does not control timing and the AFR is badly controlled so you need an ECU flash with RBs. Before doing anything, fix your misfire (try replacing the spark plug, coil pack and injector on the affected cylinder), because with the RBs you will get a lot more misfires if the engine is not in good shape.
07-08-2013, 09:24 AM | #3 | |
DIYER
614
Rep 5,521
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
07-08-2013, 09:27 AM | #4 |
DIYER
614
Rep 5,521
I would also get some NGK 5992 plus, flash and honestly meth. Meth is very safe if you do it right...get stainless lines, trunk mount and your are good to go.
07-09-2013, 12:30 AM | #5 | |
Rep 589
What is this NGk plugs, colder? U mean the bms flash? About the meth I saw in everyone thread that I have to replace the fuel pumps And I don't understand anything in this stuff In israel I'm the only car that going to be with the rb's Actually I'm the only 335 FBo here And no one know how to deal with that engine,problems And So.....
2008 e92 335 FBO
