JB4 map 5 and map 2.... 1/4 mile time= 13.5????
07-08-2013, 02:38 AM | #1 |
JB4//KW V3//VMR 19" 701//INJEN DCI
Rep 35
Title says it all. It was a 85 degree day and engine temp was reading 240... Is that a normal time for the JB4 with 94 octane. I was expecting to be in the low 12's
07-08-2013, 12:21 PM | #5 |
Rep 2,017
Drives: AW 07 e92 335i + AW 11 X5 35d
tires? FBO?
07-08-2013, 04:14 PM | #6 |
2020 Z4 M40i - 2022 M4C Convt
3129
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Without downpipes you should be running map 1 if you want to use a fixed map. If you use map5 you need to be sure its acclimated with at least 3 WOT runs in 3rd gear.
If you acclimate map 5 then go to another map you have to redo the WOT runs when you switch back because it loses everything it learned on a map switch. The WOT runs will give it a quick head start in learning the car. They are not necessary because the car is always learning with map 5 unless you are doing map switching to make comparisons & have a major change in fuel quality that you need to dial in fast. Car should run a bit better but I would not look for low 12's on just a tune with pump gas. It would need E85 or 100 octane mixed in.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
07-08-2013, 04:16 PM | #7 |
Bavarian Murder Weapon
Rep 249
Drives: E90 335i 6MT
a lot of factors for this. need more details.
07-08-2013, 06:55 PM | #9 |
Some say...
239
Rep 4,296
Drives: Fresh
I ran a 13.5 bone stock.
I have exhaust and an intake... |
07-11-2013, 10:17 AM | #10 |
Rep 35
think i found out the reason why... yesterday i had long cranks and shaking engine like a misfire, but it wasnt a misfire because it was at engine start up. last night i took the jb4 off of my car and still today long cranks, but no misfire or shaky engine. i feel an HPFP issue brewing in my car.
agreed? |
07-11-2013, 10:24 AM | #11 | |
Rep 35
thank you for your advice... thats stuff i didnt know. on the map guide that i printed off it doesnt say or note any of what you just said for the different maps. i just went and looked at the latest sheet though on N54tech and it states some recommendations, but what you said is more useful to me. i have 19 inch wheels and wide tires in the back, 275 and 245 in front. i should be in the 12's at least, but with HPFP issues, im wondering if the car realized that and wouldnt up the boost that a tune was trying to push through it. the car has run a lot quicker before, a lot different than the way it ran at the track so i know it is capable of doing a lot faster, but first i need to get this shakey engine and long cranks fixed. |
07-11-2013, 10:35 AM | #13 |
Rep 1,076
Drives: 07 335i e93 6MT
07-11-2013, 10:46 AM | #14 |
Rep 2,017
07-11-2013, 10:51 AM | #15 |
Rep 2,210
track location? timeslip? so many variables in a 1/4 pass its impossible to say anything without knowing a lot more about the pass. As far as we know this took place at 10,000' elevation and you had a 2.6s 60'
07-11-2013, 10:52 AM | #16 | |
Rep 2,017
07-11-2013, 07:35 PM | #19 |
Rep 3,552
post up the slip.
60'? If over a 2.1-2.2 you need to work on your launch. (auto awd cant be that hard) trap speed? car running ok? hitting target boost? |
07-11-2013, 08:52 PM | #20 |
Rep 913
What was your et? That will give a pretty good indication as to whether you are making the power you should be. If you are, then it is likely just a practice your launch type of thing.
Altitude can also hurt ya. |
07-11-2013, 10:01 PM | #21 |
Rep 1,595
Drives: 2011 335i xDrive Msport
