Broken belt
07-07-2013, 10:08 PM | #2 |
Rep 2,291
You are correct. The real solution is replacing the engine mount. Is your car aligned properly? I know BMW is at fault with this issue, but I'm curious if it is more prevalent on cars out of alignment.
07-07-2013, 10:19 PM | #3 |
Rep 142
There is a groove in the subframe it would appear its been rubbing for some time.
The car currently runs and tracks nice and straight. Although its Been some time since its last alignment How long of a job is replacing the subframe and mount? |
07-07-2013, 10:35 PM | #4 |
Rep 725
mine went two days ago but it was due to a bolt missing out of the pump don't know if it was never installed from factory or it just rattled loose over time . only problem I had is the belt cut a grove into the front turbo intake pipeing .not all the way through as far as I can tell but I bet this has happened to a lot of people and they never noticed it .
ptf MHD E85 /Hexon rr550 turbo's/PRE custom intakes/CP / bms dp's/hfs4 / er fmic/PSS/spec stage 2+/kwv2/steveAZ stage 3 lpfp /m3 control arms/powerflex black/MF LSD /fuel it port injection
07-07-2013, 11:59 PM | #5 | |
Rep 817
07-08-2013, 06:31 AM | #7 |
Rep 187
I have replaced my belt twice now and the pulley once I now carry a spare belt in the trunk.. Called BMW NA about it had the dealer look at it but they wont help out at all about the sub frame and stuff.
07-08-2013, 08:19 AM | #8 |
Rep 142
07-08-2013, 10:12 PM | #9 |
Rep 725
yes you do and im talking the power steering pump. I bought a new pully just incase but mine was fine .
07-09-2013, 11:38 AM | #10 |
Macgyver
208
Rep 942
Has anyone thought about shimming all the bolt locations to drop the subframe 1/8-1/4" ? Get a pattern cut out of the bolt hole by making a paper template and then reinstall them with longer screws as necessary. Or like other people have recommended, grind away or notch out under the PS pump pulley. No one has done this? Anyone have pictures of this completely taken out? It would be nice to discuss a non dealer solution with parts , templates , and cost. I personally have not had this issue but I assume everyone will.
GTX3076R , ADV, JB4, FMIC, BOV, 17"APEX, 255/40/17 SQ, 6-SPD Manual
07-10-2013, 08:25 AM | #12 |
Rep 2,291
07-10-2013, 08:58 AM | #13 |
Rep 725
think grinding away material off the sub frame is a bad idea.. someone correct me if im wrong .but I think you will loose structural integrity that way . and not sure if lengthening everything would work .
07-10-2013, 10:29 AM | #14 |
Rep 142
The area of contact is comprised of two 1/4 inch pieces of aluminum formed and welded on top of each other. The top piece is a support patch welded on top of the corner of the subframe where 2 pieces are welded together to make the 90 degree turn. The contact point appears to be 1/16th deep groove rubbed in the aluminum. I plan to remove about 1/8 inch of material in a total area the size I a quarter. The top welded piece is about 3 inch by 4 inch triangle.
07-10-2013, 01:13 PM | #15 |
Rep 340
Bmw told me it was " due to spiritted driving". They argued that it was my fault and refused to pay anything. Then they tell me its a common problem and the subframe is being redesigned. I said why would Bmw redo a part if its driver error? They ended up paying for the new subframe.
07-10-2013, 11:46 PM | #16 |
Rep 725
would like to see a pic of old vs new sub frame
07-11-2013, 01:06 AM | #17 |
Rep 564
07 AW E92 335 6MT [18" OEM 193's For Sale, PM me] OEM Aero Lip | OEM Gloss Black Kidney Grills | KW V2 | Vorsteiner CSL trunk | M-Tech Rear Bumper | LCI Rear Taillights | Angel ibright Angel Eyes | 3000K HID fogs | 6000k HID low beams | AFE DCI | Full LED conversion |
07-28-2013, 04:44 AM | #22 |
Rep 1,948
I thought this was a recall issue. Doesn't the dealer cover recalls even if you are out of warranty? I had mine done, and the dealer replaced my entire motor as bits of the belt ended up in the engine valve body. I was under warranty then but I remember the dealer saying there was a recall or something. Maybe I got it wrong.
