help with these codes
07-06-2013, 01:14 AM | #1 |
Rep 1,909
30FF Boost under target -- possible boost leak
2F84 No Description Found 2F81 No Description Found 2F9E Thermic oil level sensor |
07-06-2013, 01:21 AM | #2 |
Rep 6,478
You could have a boost leak from any number of places. On the cold side check the TB, manifold, charge piping, diverter valves, etc. If you can eliminate those parts go to the intercooler couplers and work back towards the turbos. Vac lines can also cause underboost issues.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
07-06-2013, 08:46 PM | #3 |
Rep 1,909
Holy Guacamoly I have several issue..
Used this great DIY http://www.n54tech.com/forums/showthread.php?t=13114 1- Its not holding pressure at all... diverter valves are OPEN as in WIDE OPEN.. Swoooooooshhhhhhhing out air 2- the charge pipe had a missing bolt it was pretty loose 3- thats how far I could get as yet what do I do with diverter pipes ? Is it possible to tighten the spring.. If I order new ones I dont know if the male's leakin or female...... |
