Misfire cylinder 5
07-05-2013, 08:12 PM | #1 |
Rep 888
Misfire cylinder 5
Sp after going to the cobb aggressive map, I had cylinder 5 misfire. I didn't do or change anything, I just wanted to see if it would happen again. Today went WOT and it happened again. I had my spark plugs changed 4k miles ago so I know it isn't that. I wanted Ian's video from Cobb and he said th enext thing is probably coil pack.
I did not sap the coil packs to test yet, but if it was the same cylinder that misfired both times then doesn't that mean it has to be the coil pack, considering that it definitely can't be the spark plug. I want to know for sure if this means its the coil pack before I go ahead and order one. |
07-05-2013, 08:22 PM | #2 | |
335i Owner
56
Rep 839
Drives: BMW 335i 4 Door
Just buy coils man.. They're $35-38 a pop shipped... |
07-05-2013, 08:24 PM | #3 |
Rep 888
07-05-2013, 08:26 PM | #4 |
335i Owner
56
Rep 839
If you only have a misfire on cylinder 5. I had a misfire on cylinder 6, shut my car off then it switched to cylinder 3. Your best bet is to buy 2 coils... you know you need to replace at least 1 and chances are you'll need to replace 2 or more. If not you will need to replace them eventually, for an inexpensive $38 it's worth it IMO.
07-05-2013, 08:44 PM | #6 |
Rep 888
Yeah I saw the video on youtube of cobb explaining this, but I figured since the misfire was on the same cylinder twice, it has to be the coil. If it is the injector, what does that mean? Also, I see coil packs going for 50, where do you guys get them for 35?
07-05-2013, 08:58 PM | #7 | |
335i Owner
56
Rep 839
$36.25 |
07-05-2013, 09:01 PM | #8 | |
Rep 888
07-06-2013, 06:44 PM | #9 |
Rep 888
Just ordered a coil pack. Also will be ordering a fmic and will switch to cobb stage 1+ fmic map. Is it okay to switch to this map before getting the cylinder misfire fixed?
07-06-2013, 06:52 PM | #10 |
Rep 6,478
