Whats the best mod to lower temp
07-04-2013, 09:14 AM | #1 |
Rep 1,909
I sit in stop & go traffic a lot, lately my oil temp's starting to hit 250 (the only change I did was switched from 5w-30 to 0w-40 castrol) ... I was thinking adding another oil cooler ... or just should I consider an intercooler ... I dont know pls advise the best mod for extreme stop and go driving
07-04-2013, 09:19 AM | #2 |
Rep 1,843
both are good mods but oil cooler or aux water cooler are the ones that will actually keep your engine cooler. FMIC primarily just keeps the intake temps low under long periods of high power demand.
07-04-2013, 09:22 AM | #3 | |
Rep 1,434
2022 x5 m50i - Dravit grey
2005 evo 8 (current) built 2.3 488/409 mustang dyno Old stable mates - 87 325i, 88 m3, 90 m3, 97 m3 4dr, 04 325xi, 91 gmc Syclone, 08 335xi, and 13 x3 35i msp 2014 x5 50i msport |
07-04-2013, 09:22 AM | #4 |
Rep 911
Use 5w40 bmw certified oil.
My aux cooler is helping to lower the temps as fast as possible back to acceptable temps. My oil cooler keeps the oil within preferred range. Get a decent oil cooler if you are going to invest, to my regrets the AR did not do much...
BMW 335 E92 09 - Full options - DKG - MHD by Buraq - RB Next Gen - RB Inlets/Outlet - Forge Diverter Valves - AR Catless DP - Afe Intake - Helix IC - FuelIT Stage 2 LPFP - Ar Oil Cooler - PPK Water Cooler - M3 Suspension - JRZ RS1 Shocks - Eibach Pro Springs - Drexler LSD - BMW IS Exhaust - Carbon Endurance Brake Pads - Stainless Steel Brake Lines - M101 Wheels - Michelin PS2 - M-Tech Body - M-Strutbar
BMW M550i G30 2019 - BM3 |
07-04-2013, 09:26 AM | #5 |
Rep 579
Drives: 08 AW e92 335i
The bms thermostat bypass works well if you have the stock oil cooler and don't want to invest in an upgraded cooler. Also FMIC is a must imo, even with running meth.
11.76 @ 124mph (123.9) full weight/street tires/no meth.
07-04-2013, 10:58 AM | #7 |
3441
Rep 79,211
Just under 250 is normal operating temp for this particular BMW.
If you are looking to get those temps lower any aftermarket oil cooler and preferably thermostat delete would take care of it. I'm assuming since your asking about adding another oil cooler that you have one already? Stock or aftermarket? |
07-04-2013, 11:00 AM | #8 |
Joint Chiefs of Staff
4918
Rep 115,980
07-04-2013, 12:51 PM | #9 |
DIYER
614
Rep 5,521
I still stand behind my stett.
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
07-04-2013, 02:50 PM | #10 |
Rep 1,525
Temps
07-04-2013, 03:07 PM | #11 |
3441
Rep 79,211
07-04-2013, 08:53 PM | #14 |
Rep 494
Your oil temps are normal, and if you are in stop and go traffic oil cooler will not be much help since it needs you to move in order to cool. How many miles on the oil? Old oil heats up much faster too.
07-04-2013, 09:02 PM | #15 |
DIYER
614
Rep 5,521
I have no argument with that.....that's why I deal with vendors like yourself
07-05-2013, 12:47 AM | #16 |
DIYER
614
Rep 5,521
Have to disagree...I was stuck in traffic in 111 degree heat and oil never went over 225.
07-05-2013, 07:48 AM | #18 |
Rep 1,909
07-05-2013, 09:11 AM | #19 |
I even mod my cereal
246
Rep 3,441
Drives: 11 ZCP DCT M3 14 328d 21 GT4
The cheapest alternative (as stated above) is definitely the BMS thermostat delete.
Another option would be the CP-e Intercooler which comes with a extra oil cooler (mounts on top of the FMIC) and it works pretty well. You must have a factory oil cooler to work and its not as good as an AR or ER unit, but it will take temps down about 20 degs. The price for the FMIC is reasonable and is the only FMIC that comes with an external oil cooler.
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser |
07-05-2013, 09:16 AM | #20 |
Rep 1,909
thanks for input guys, I dont want additional load on the electronics (Water pump/ fan etc) I'd rather add on accessory to help run cooler
07-05-2013, 09:40 AM | #21 |
Rep 494
Mine stays around the same temperature in traffic too with stock oil cooler, but creep up if I push it and have not seen above 250 yet after oil change. With OEM oil it would creep up to 260 with few thousand miles on it and especially when driven harder. For oil I have RLI 5-40HD low ash.
