Rough idle when cold, code 10705
07-03-2013, 06:16 PM | #1 |
Rep 373
I get a misfire reading when I start the car after a long time not being driven (about a day when the temperatures are all back to normal). After a few restarts of the engine, everything seems to be fine. What would cause this initial problem which gets better after a few starts? Once the engine is warm, this never happens.
I replaced the plugs and low pressure fuel pump. Is it the ignition coils or high pressure fuel pump? |
07-04-2013, 02:09 AM | #2 |
Rep 373
The answer is either injectors or ignition coils. I am 80% sure. I will migrate some coils to see if the misfire migrates accordingly. I sure hope it does! Injector replacement is a relative PITA and I might just stealership that, given my limited tools.
07-05-2013, 01:35 AM | #3 |
Rep 373
I swapped ignition coils 1 and 2 to see if the misfire would migrate. I did this before starting the engine for the day, so the block was basically room temperature. Upon starting the engine, I got no codes whatsoever and the idle lacked misfires.
Curious about this, I swapped the coils again, back to the position they were at when I got the misfire, and waited a few hours to cool the engine. Upon starting, still no codes. I waited a few more hours for the engine to cool down once more. I tried again, no misfires. I will be starting the engine again the next day once it is *truly* at room temperature to see if I can get that 10705 code. I really want to reproduce this problem so I can localize the problem to the ignition coils, but this is an elusive problem. Anyone have any ideas? Could any of this hard-to-reproduce behavior be attributed to injectors instead of coils, or is the best that can be done at this point the same speculation I am offering in this thread? |
01-13-2014, 01:48 PM | #4 |
Rep 373
Turns out the problem is crappy injectors. Injector #6 was completely toast, and was leaking fuel when cold. Eventually, it got to the point that, even warmed up, the engine was misfiring 100% of the time. Injectors #2 and #4 will be the next to go, upon checking for voltages when reprogramming for the replacement #6 injector.
01-13-2014, 03:55 PM | #6 | |
Rep 62
I need to change my injectors as well, getting as much information before I change them out. Thanks... |
02-25-2014, 11:34 AM | #7 |
Rep 373
It is something you have to program into the car when you get new injectors. I do not know the details, but I do know that there is some sort of variance in the voltages that each injector has. They are tested, and a voltage (or something) is printed on the side of each part. Those numbers you have to program into the car, so it knows how each injector responds electrically.
