Meth intergration question???
07-03-2013, 01:53 PM | #1 |
Rep 605
Quick question, I finally got my hands on 100% methanol, I was using windshield wiper fluid as an alternative ( 30/70) and my question is regarding the settings for the JB4 meth integration. My current meth additive psi is set to 30, since I'm using 93 pump, but since I'm going to use 100% instead of a mixture what would be a good setting to put it on, 50 perhaps? The reason I'm asking is because I recently upgraded to the G5 board and I know it can pull a little bit more power compared to the G4. Also, would it be safe to change my boost fail safe psi, since I will be running full meth?
F90 M5 Comp/ FI Exhaust, MAD pdownpipes / PG Intakes/ H&R Springs/ AG wheels
E85 Z4M |
07-03-2013, 02:19 PM | #2 | |
Rep 1,525
Meth
07-04-2013, 01:46 AM | #3 | |
DIYER
614
Rep 5,521
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
07-04-2013, 02:37 AM | #4 |
Rep 605
Im not sure what nozzle I have (http://www.topgearsolutions.com/cmbmwaun.html). So by increasing the additive settings, how much power/psi can I actually extract from the G5? Is 18.5 psi the highest it can go, according to map 7?
E85 Z4M |
07-04-2013, 02:41 AM | #5 | |
Rep 315
Also, you really should get the meth FSB from BMS. I wouldn't run meth on the jb4 without it. |
07-04-2013, 03:44 AM | #6 |
Rep 605
I have the fsb installed, which the system and I'm able to use meth on map 5 as well. I set the CMGS controller to start spraying at 3 psi all the way to 17 psi.
E85 Z4M |
07-04-2013, 11:57 AM | #7 |
DIYER
614
Rep 5,521
+1
