More exhaust "gurgle" without catless dp's?
07-01-2013, 09:07 PM | #1 |
Rep 409
Hi everyone,
I've decided for now that I'm not ready to mess around with catless downpipes. I don't want to fuss with CEL's and readiness yet since I have an '09 and will be due for emissions within the year. However, I still want the gurgle sound of the downpipes. I miss the lively gurgle of my old mini cooper s, the 335i sounds so much better (and gurgles a tiny bit) but it doesn't have the character. Yeah, I know I can tune out the CEL and I have a dpfix laying around, but I'm just not messing with it for now. I have a cobb accessport in the mail, and will be downloading ATR once I have the info to request it. Is it possible to tune the overrun in ATR to produce more exhaust burble? If so, where in ATR would I accomplish this? Thanks in advance, I appreciate it
2009 E92 335i M-Sport - MHD Stage One - BMW Performance Exhaust - BMS Oil Catch Can - CDV Delete - K&N Panel Filter - Arc Angel H8 bulbs - Gloss Black Kidney Grills - Painted Reflectors - VRSF Charge Pipe
07-01-2013, 09:16 PM | #2 |
Rep 1,843
I'm running the Stage 1+FMIC with only a "MIG golf tee" (welded the flap open because it was worn and rattling, and I didn't want to listen to it anymore) and it's got a nice little bit of the snap crackle pop I remember from my old VW days...
07-03-2013, 12:02 AM | #3 |
Rep 409
Yeah I have a tiny bit of gurgle, would love some more. Bump, anyone?
07-03-2013, 12:10 AM | #4 |
Rep 6,136
If you made your lambda AFR's richer in ATR that would do it, but I would avoid going that route. You can delete your secondary cats and/or plug up that vacuum muffler valve.
07-03-2013, 12:16 AM | #5 |
Rep 3,732
Drives: BMW S1000XR
^^ this, so I would recommend a different exhaust such as; Vanguard, Dinan, BMW PE, or BMW 'IS" for more gurgle. Then, when you get DPs
BMWCCA member |
07-03-2013, 12:51 AM | #6 |
Rep 409
Gonna keep secondary cats for when I have downpipes. Did the golf tee/unplug mod the day I bought the car lol. If I can come up with double the cash I need for downpipes plus install from my summer job, I'm gonna get them . Would love BMW pe too, but that's not gonna happen for a while.
Thanks, I'll try lightly adjusting the lambda afr. Loving stage1 aggressive, just got the Cobb today. Edit: Which table in ATR is for the lambda AFR? There isnt once specifically called lambda AFR under "fuel tables"
07-03-2013, 10:24 AM | #7 | |
Rep 6,136
07-03-2013, 10:46 AM | #8 |
3441
Rep 79,211
This is like the 3rd of 4th thread this week...
Guys the whole flames and gurgle thing is your car running rich and this is not optimal from a tuning standpoint. Sure this BMW gurgles normally and yes it's just excess and un-burnt fuel. If you want the noise and visuals richen up your AFR but I'm not recommending it. |
07-03-2013, 10:53 AM | #9 | |
Rep 1,843
The old school big cracks and flames shooting out the tailpipes on overruns was because carburetors and very early FI systems don't have closed throttle fuel cutoffs - cool to watch, but inefficient. |
07-03-2013, 04:27 PM | #13 |
Rep 409
Thanks for all the input. I'll play around with slightly richer AFR's tonight, but it sounds like I really need downpipes to get the sound I want (or muffler delete, but that's probably louder that I want it)
07-03-2013, 10:50 PM | #15 |
DIYER
614
Rep 5,521
Muffler delete + secondary cat delete + 1792 resonators + 1141 Ultra quite resonators =
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
07-04-2013, 01:29 AM | #19 |
DIYER
614
Rep 5,521
07-04-2013, 02:16 AM | #20 |
Rep 116
If you dont want to go catless, what about racecat? I dont know how much it will the increase the sound level but it should. Not sure but racecats will be sufficient to pass emission test no?
Doing Golf tee mod helps a lot and a worn stock exhaust just sounds lovely. I wouldnt change afr, it's not that straight forward as installing catless DP and the fix.. be happy that there exist a way to pass the readness. |
07-04-2013, 03:03 AM | #21 |
I wanna go fast!
14
Rep 343
Drives: like a madman.
Rather than messing around with the AFR tables, you could just lightly tap the gas pedal on decel and that will re-activate the fuel causing gurgle on command.
07-04-2013, 11:04 AM | #22 |
3441
Rep 79,211
