Turbo need replace Rb's vs Vargas , help needed
06-30-2013, 06:34 AM | #1 |
Rep 589
My car 335 e92 2007
Jb4 Aa dp Injen dci Forge dv' Akrapovic Aa intercooler 90k km Turbo rattle started 2k km ago Thinking on upgrade turbos but I don't know where I'm going I'm from israel and this cars very hard to find maybe 30 cars sold in israel from 2007 Last Dyno I pull out 370bhp My turbos close to die I don't want meth And I want to keep the car as is daily driven I don't track .... Just want more power with minimum issue and problems Thinking on the rb's or Vargas I'm thinking 450-500hp will be more than ok for me but I don't want squeeze the juice from the engine . And all the info I found doesn't answer all my questions. How much power my at trans hold(alpina flash done)? What I need to do with program and how much it should cost? Any more stuff to replace? Fuel pumps ? Pcv ?(I don't understand what it) Better plugs? Better coils ? Can Someone here make it clear And tell me where I'm going and how much ?
2008 e92 335 FBO
2011 e92 M3 ZCP DCT 2015 f82 M4 DCT |
06-30-2013, 07:18 AM | #2 |
Rep 911
Thinking on the rb's or Vargas (RB's proven, Vargas newer) Sufficient info on the board
How much power my at trans hold(alpina flash done)? 450tq, flash does not matter What I need to do with program and how much it should cost? nothing, tune... Any more stuff to replace? As it is quite an operation, you could consider replacing stuff which would normally require the same labour activities Fuel pumps ? Only when they die or when you want to run with Ethanol higher then 50-70%, especially LPFP Pcv ?(I don't understand what it) A valve... replace it when you order new turbo's... has to do with poor BMW design and increased pressure. Better plugs? Better coils ? Not really required. All info on this is very well documented on the board..
BMW 335 E92 09 - Full options - DKG - MHD by Buraq - RB Next Gen - RB Inlets/Outlet - Forge Diverter Valves - AR Catless DP - Afe Intake - Helix IC - FuelIT Stage 2 LPFP - Ar Oil Cooler - PPK Water Cooler - M3 Suspension - JRZ RS1 Shocks - Eibach Pro Springs - Drexler LSD - BMW IS Exhaust - Carbon Endurance Brake Pads - Stainless Steel Brake Lines - M101 Wheels - Michelin PS2 - M-Tech Body - M-Strutbar
BMW M550i G30 2019 - BM3 |
06-30-2013, 07:23 AM | #3 |
Rep 865
Drives: BMW X3 35i, Porsche Macan S
I recently added RB Turbos and am very happy with them. RB has been shipping for a few years now and have several international customers so you should consider this. RB website has all pricing information. Vargas stage 2 also looks very good so it is not an easy choice.
Your transmission should be able to handle the added power but obviously you are adding stress. Your JB4 is good with RBs but work with Terry to dial in tune. You might also consider BMS backend flash with RBs. Definitely order the RB PCV valve at the same time. Do you have an OCC? If not consider adding BMS one. Your stock fuel pumps will be fine unless you are running E85 mixture over 40%. What fuel are you running now? No need to change coils but definitely put in new plugs if it has been more than 10,000 miles since you changed them last. Good luck!
MOTIV 750 ST | MOTIV PI | 100% E85 | Fuel-it Stage 4 LPFP | MOTIV Boost Box + MHD Protune | Quaife | Öhlins | Brembo | Akrapovic
06-30-2013, 07:49 AM | #4 | |
Rep 589
how much power will give me the rb without damage the trans? i talked with terry he said i need cobb ap and g5 board , will be another 900usd whats the bms flash? i don't want meth or ethanol or all of this i'm on 93 octane *i saw somewhere rob post not to use occ with is turbo....
2008 e92 335 FBO
06-30-2013, 08:05 AM | #5 | |
Rep 865
06-30-2013, 01:31 PM | #6 | |
Rep 589
I think I will get the install kit from rob and the Pcv valve So we talking about 50 Hp ? Only ? Bms occ Cobb ap + g5 upgrade And done.... I'm on 450 Hp
2008 e92 335 FBO
06-30-2013, 01:37 PM | #7 |
Rep 1,290
Dont get wrapped up with the 50HP gain number... Its about the curve, you will have WAY more power under the curve as you can run higher boost to redline on RBS or VArgas2
- Proven Power Tampa Built 6466 ST N54 6AT WR 711whp 637wtq -
06-30-2013, 01:40 PM | #8 |
Rep 865
+1
06-30-2013, 02:16 PM | #9 |
DIYER
614
Rep 5,521
RB'S are performed for sure...I run a very aggressive curve daily driver, meth, E85, flash ECT And all had been great.
Herr is a example of a what a RB curve can look like...notice how long it holds boost? Then good down to 18 then fou right back up.
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
06-30-2013, 02:20 PM | #10 |
Rep 1,290
EPIC log
06-30-2013, 02:40 PM | #11 |
DIYER
614
Rep 5,521
06-30-2013, 03:40 PM | #12 |
Rep 1,525
Rb or Vargas
I just got off the Dyno I think last week I hit 506whp 523tq with RBs and no meth jb4 g5,rb PVC,BMS occ, walbro 455 on e70 for fuel........choose your poison....lol. Terry was tuning my car via email andmtexts I spent most of the day on the Dyno. In my my opinion you will not receive that kind of customer service from anyone else.
07-01-2013, 10:45 AM | #14 | |
Rep 589
by cobb, the bms flash yes? all i can see this trip going to be about 5000$
2008 e92 335 FBO
07-01-2013, 01:59 PM | #15 |
Rep 1,525
Turbo
07-01-2013, 02:01 PM | #16 |
Rep 420
one idea about the price between different turbos ??
335i Pack M Stage 2 BR Performance 403,5 hp 582n.m/Bilstein B14 pss/R&B PVC2 valve/K&N air filter/Spearco FMIC/pre cata empty/EBC Redstuff,aviation hose, BMW Performance exhaust, Charge pipe Evolution Racewerks, Forge DVs
07-01-2013, 02:09 PM | #17 |
Rep 865
http://www.e90post.com/forums/showth...on+chart+turbo
This really needs to be a sticky.
07-31-2013, 11:44 PM | #18 |
Rep 589
Can I save some money on the Cobb
And just order the open flash tablet ?
2008 e92 335 FBO
07-31-2013, 11:45 PM | #19 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
08-01-2013, 12:54 AM | #20 |
Rep 182
Do you have a bt cable? If you are interested in saving money there is another tune coming out that only needs the BT cable to flash your car with any map. Also I would look into a piggy (jb4/proceede) on top of a flash tune. From all of the threads I have seen it delivered very very good consistent results. I can vouch for the piggy + flash for e85 makes the car so much smoother
08-01-2013, 02:00 AM | #21 |
Rep 589
it will work with the jb4? i can load the bms flash with it?
2008 e92 335 FBO
