New turbo's with p30ff code but STILL P30FF
06-30-2013, 03:14 AM | #1 |
Rep 43
Hey everyone, I just had my turbos/WGs replaced because of a p30ff error code. The code started coming on when I got the Cobb AP and boost levels increased.. the thing is, the car holds stable under low boost and pulls hard but once the boost gets to a certain level it makes a really loud WOOOSHHHHHH sound like there's air getting forced out of a hole somewhere. I uninstall the tune when I take it to the dealer but when the tune isn't on the car, the engine malfunction sign only comes on when you're going 120.. They just disregarded it and told me that there weren't any leaks when i took it in after the initial tubor replacement, and that the turbo's were resetting. I KNOW for a fact that there is a leak that gets worse as boost increases, i replaced my charge pipe, intake, and DV's to make sure it wasn't from any of those (needed to mod anyway) and the problem persisted. Is there anything I can do on my own to find out what's wrong with it, or something I can tell the SA at BMW I think is possibly a problem with my car?
*IN a nutshell: with regular BMW flash, car doesn't lose much boost at all. With Cobb AP and increased boost levels, HUGE boost loss and engine malfunction sign comes on. Also, another "p--" code, about boost pressure on loader 2? I have no idea how to find out what or where loader 2 is. Thanks for the help |
06-30-2013, 09:08 AM | #2 |
Rep 420
when you are stock no tune, also the 30ff ?????
335i Pack M Stage 2 BR Performance 403,5 hp 582n.m/Bilstein B14 pss/R&B PVC2 valve/K&N air filter/Spearco FMIC/pre cata empty/EBC Redstuff,aviation hose, BMW Performance exhaust, Charge pipe Evolution Racewerks, Forge DVs
06-30-2013, 10:14 AM | #5 |
Rep 6,136
Clearly the turbos arn't your 30FF source then. Could be vacuum lines, boost solenoids, or vacuum canisters. If you are sure your intake tract has no leaks (smoke test it post turbo to be sure), then vacuum loss is probably your source of the leak. Your stock intercooler connections can still leak, and the plastic end tanks can even crack, so be aware of that.
06-30-2013, 12:42 PM | #6 |
Rep 43
06-30-2013, 12:43 PM | #7 |
Rep 43
06-30-2013, 12:47 PM | #9 | |
Rep 43
06-30-2013, 01:08 PM | #11 | |
Rep 6,136
Not true, only the wastegate vac lines are changed. |
06-30-2013, 01:19 PM | #12 | |
Rep 43
I'll check the IC soon, for now, running to pepboys or somewhere to see if they have pressure testers or somehow know how to find leaks lol |
06-30-2013, 01:21 PM | #13 |
Rep 43
I've read on someone's post that they've had their lines changed and had to pay for it even though they had warranty, I think they didn't change it on mine because i had a third party warranty and BMW wanted to keep the cost low for me. Although I had a $50 deductible and had to pay ~$165 altogether
06-30-2013, 01:22 PM | #14 | |
Rep 6,136
06-30-2013, 01:24 PM | #15 | |
Rep 43
06-30-2013, 01:28 PM | #16 |
Rep 43
Well see, when I rigged the line to the DV it was working as it was before I got the turbo's replaced, (yes, putting my mods in made it worse, but i corrected it with the jerry rig )it would only malfunction at higher MPH like ~100 depending on whether i'm going WOT the whole time, it usually doesn't mess up unless i put too much throttle. If i barely press down on the pedal it'll of course speedup a lot slower but i don't think they leak catches enough for it to want to disconnect or throw out pressure/malfunction sign... until i go wot then WOOOOOSHHHHH bye bye boost
07-01-2013, 08:48 PM | #18 | |
Rep 43
07-01-2013, 09:12 PM | #19 |
Rep 6,136
07-02-2013, 02:23 PM | #20 |
Rep 43
Well I fixed it and I still get engine malfunction but not nearly as quick as it was with the two leaks. I'm starting to think it's solenoids or hpfp? It usually doesn't happen now unless i'm in a single gear for too long, occurrences arise from 4.5-7krpm never lower. Well I haven't tried in 6th going 120 so i'm not sure about underboost or something similar. Help? The dealer will probably try to blame the charge pipe, dv's and intake, not sure if it would be legitimate but sure, they'd say it's not up to standard equipment and say that's why i'm getting malfunctions. I can easily see that happening.
07-02-2013, 02:40 PM | #22 |
Rep 43
I could log with the Cobb to see the problem but I have no clue how to do anything with logs because I haven't yet had time to look into Cobb's forum section, i'm about to now and will try to find a way to diagnose the problem
