Rear pre turbo inlet pipe removal
06-29-2013, 08:49 AM | #1 |
Rep 1,392
Has anyone successfully removed the rear pre turbo inlet? Its the only piece i haven't removed. Looking at some people's turbo upgrades they just left it in. I even lowered the motor fit extra clearance. I'll probably end up cutting it out but just wanted to see if anyone has had any luck or know of a trick.
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust 335i 2009 e90 665RWHP VFF900 ST RIP . |
06-29-2013, 10:45 AM | #2 | |
Rep 1,202
06-29-2013, 11:39 AM | #3 |
Rep 748
I removed the rear tube when I had the transmission out for the clutch swap. I had to cut the front one to remove it. I would hate to have to install either.
2008 335I E92, AW, VFF700, 18" Forgestar F14, M3 front/side, M-tech rear, AMS IC, H&R Touring Cup Kit suspension, HID AE, ER Charge Pipe & Synapse BOV, CIC Retrofit, Quafie, DSS, Defiv Lockdown, SPEC 2+/Steel SMFW, Walbro 450
06-29-2013, 11:44 AM | #4 |
Rep 538
It's not easy and it takes up some time. I usually lower the engine by several inches, of course the cowling and strut braces need to be removed. The airfilter-side comes up first, then the turbo side comes out last. I usually use a pry bar to push the engine forward and to the drivers side to get the last little bit of clearance between the valvecover and DME shield. HTH and GL!
06-29-2013, 04:43 PM | #5 |
Rep 1,392
Damn you guys have way more patience than i do. I fought it for about 15min. Then posted the thread grabbed a bite, saw no one posted at the time then cut it out. Lol was hoping to save it for when i go back to stock, that'll never happen. Thanks guys
06-29-2013, 04:43 PM | #6 |
Rep 1,392
06-29-2013, 09:47 PM | #7 |
Rep 1,183
why were you wanting to remove it ?
06-29-2013, 09:52 PM | #8 |
Rep 1,392
Single turbo install
