JB4 Maps
06-27-2013, 07:50 PM | #1 |
335i Owner
56
Rep 839
Drives: BMW 335i 4 Door
JB4 Maps
What map should I run my 335i on?
I have JB4 JuiceBox BMS DCI Thanks! |
06-27-2013, 08:01 PM | #2 | |
Rep 1,290
if you want, put 4 gallon of E85 to 12 gallon of 93 if its available in your area and run map5!
- Proven Power Tampa Built 6466 ST N54 6AT WR 711whp 637wtq -
06-27-2013, 08:02 PM | #3 |
335i Owner
56
Rep 839
06-27-2013, 08:18 PM | #5 |
335i Owner
56
Rep 839
06-27-2013, 08:21 PM | #6 |
Rep 913
Fueling depends on what you have in your area. If you have e85, mix it properly and you can get gobs more power than running straight 91 or 93.
yes, put it on 5 and forget about it. |
06-27-2013, 08:41 PM | #7 |
2020 Z4 M40i - 2022 M4C Convt
3129
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Map 5 regardless of fuel. Try for about 35/40% max E85 into 91 or 93.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
06-27-2013, 09:07 PM | #8 |
335i Owner
56
Rep 839
06-27-2013, 09:25 PM | #9 |
Rep 155
No you don't need to fill your tank up full, if you google e85 calculator you can use it to see what mixes you can make, (most 91 or 93 at 10% ethanol in it and it does include that) It's also usually better to switch to map 0 or any other map and then back to map 5 if you use a different ratio and do a few WOT pulls so your JB4 can adjust to the new E85 mixture.
06-27-2013, 09:25 PM | #10 |
Boost For Fun
Rep 32
Start with 30%...... 3 gal E85 & 7 gal of 93 or 91.
09 335i Coupe JB4 G5, Meth, DCI
08 335i Sedan 12.035 at 118.14 1.92 60 foot JB4 Meth CM5, M10 Nitto NT05R on K1's, SOLD. |
06-27-2013, 10:15 PM | #13 |
335i Owner
56
Rep 839
Thanks for all the help guys! Does it matter what I put in first E85 or 93? Do you guys like the E85 and 93 mix better then the E85 and 91 mix? What works best? What is best overall for the car?
06-27-2013, 10:19 PM | #15 |
Rep 913
if the pumps are right beside each other, probably doesn't matter what you do first. If you have to drive any sort of distance between the 2, do 93 first. I think you are over thinking this to death.
06-27-2013, 10:23 PM | #16 |
335i Owner
56
Rep 839
06-27-2013, 10:24 PM | #17 |
335i Owner
56
Rep 839
Rather be safe then sorry E85 is $3.11 a gallon and 93 is $3.99 a gallon here. So I'll be saving some money on gas obviously. Does gas mileage increase/decrease? Is this better/worse for the engine?
06-27-2013, 10:25 PM | #18 |
Rep 925
Correct.
Feed the USB cable through so you can set the laptop right on the passenger seat. Here is a DIY http://www.e90post.com/forums/showthread.php?t=65147 |
06-27-2013, 10:27 PM | #19 |
Rep 913
You likely won't be saving money on gas. Mileage is a fair bit worse with e85. Jury is still out but it is probably harder on your fuel components as well - unless with were specifically made with e85 in mind. i.e. flex fuel marketed vehicles.
06-27-2013, 10:29 PM | #20 |
335i Owner
56
Rep 839
06-27-2013, 10:35 PM | #21 | |
335i Owner
56
Rep 839
Looks simple enough! |
06-27-2013, 10:37 PM | #22 |
Rep 913
