Stage 1 sport COBB
06-27-2013, 08:59 AM | #1 |
Rep 888
Stage 1 sport COBB
I will be rubbing cobb stage 1 sport on my stock 335. I always use 93 octane, but for this stage it calls for 91. Is it ok if ibuse 93 for this stage?
06-27-2013, 09:02 AM | #2 |
Rep 342
Drives: E90 Monaco Blue 335i xdrive
always fine if you use something better. You can run sport or aggressive with 93. Just data log it to make sure everything is running silky smooth.
2010 E90 335i xdrive | Monaco Blue with Black Interior | All Packages except Sport :/ | Apex EC-7 | Active Autowerke Strut Bar | Roc Euro DCI | Roc Euro Hyperboost DVs | aFe Scoops | BMW Performance Exhaust | BMWCCA member
06-27-2013, 09:06 AM | #3 |
210
Rep 1,161
06-27-2013, 09:44 AM | #5 |
Rep 3,625
Start with the Drive map on 91 octane and log. If there are no timing corrections jump up to the Sport Map. If that map looks happy go to aggressive. This would be a cautious approach.
Have you changed your spark plugs recently? |
06-27-2013, 10:11 AM | #6 | |
Guest
Rep n/a
Drives:
06-27-2013, 10:42 AM | #9 |
Rep 6,136
There is no regular. There are Drive, Sport, and Agressive maps. If you have 93 octane run stage 1 Sport, log, if all is good then go to Agressive. I use ATR to fine tune my maps, but if you arn't willing to do so contact a protuner.
06-27-2013, 11:26 AM | #10 |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
I already told him this in one of the eleven threads he's started in the last 36 hours. I'm by no means an expert on this stuff but I do know how to
Cobb E40 PROtune by Jake@PTF/RR catless DPs/aFe DCI/ETS 5" FMIC/ER CP/Forge DVs/Alpina B3 TCU flash/BMW Perf. Exhaust./BMW Performance Style 313s/M-Tech Rear
06-27-2013, 12:06 PM | #12 |
Slow.
3782
Rep 7,152
Drives: Single Turbo N54 on Meth!
Hmm I never bothered logging on stage 1 aggressive. Would the car bog or would I notice anything if it wasn't running right/smoothly? Doesn't the car automatically protect itself?
I guess I should figure out how to log with my cobb... |
06-27-2013, 12:22 PM | #13 |
Rep 115
Higher octane is usually a good thing. Low octane could result in knocking. Also, make sure you have either a drop-in filter, or dual cone intake. The extra flow over stock makes the car happy.
+1 on what the other guys said. You are definitely better of starting with the drive map and logging, and then going to sport, then aggressive if everything looks good in the logs. Have fun! |
06-27-2013, 02:37 PM | #14 | |
Rep 961
As far as the OP is concerned, I actually disagree with the consensus a little bit. I recommend just loading the map appropriate for your fuel(aggressive for 93) and let it adapt for a day or so and then grab a couple datalogs. The OTS maps are pretty conservative and there is no risk of engine damage in this scenario. If it is a little too much then flash over to sport and log.
"I'm not surprised you get along well with all the other neighbours. If you put fifty children with Down's syndrome in a room there is going to be a lot of hugging." David Thorne
06-28-2013, 08:30 AM | #16 |
Rep 888
At VAC now and getting the cobb installed and also getting a drop in air filter. Very excited! Steve at VAC recommended fusing stage 1 sport for nice daily driving smooth power. I will post back after my first drive
06-28-2013, 08:35 AM | #17 | |
Slow.
3782
Rep 7,152
06-28-2013, 08:40 AM | #18 |
Rep 3,625
You are paying someone to install the tune and put in a filter?
06-28-2013, 09:00 AM | #22 |
Rep 3,625
