E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Spark Plugs
      06-27-2013, 02:10 AM   #1
Snaggletooth
General Nuisance
Snaggletooth's Avatar
Drives: 2007 E92 335i
Spark Plugs
I was curious as to what temp range and gap you guys with 15+ PSI are running. Any plug recommendations?
Also, do you guys index your plugs? If so, do you aim them towards intake or exhaust? I am kinda unsure where the car would be happier cause of the direct injection.
I'm curious to see if this helps some of the misfires as well.
'07 E92 335i 6MT
Full Bolt On's, Vargas Stage 2's, Carbon Fiber, and Methanol.
      06-27-2013, 02:21 AM   #2
Allaboutthehype
Drives: 335i
I run the OEM BMW plugs (Pre-gapped) and change them out about every 25k. Maybe a little crazy but I run 18+ psi with E85 and it keeps my car happy
      06-27-2013, 07:38 AM   #3
135Pats
135Pats's Avatar
Drives: A few BMWs
I wouldnt worry too much about colder plugs on stock turbos.
      06-27-2013, 07:43 AM   #4
JStang
JStang's Avatar
562
Drives: FDB M3 CS
+1
      06-27-2013, 10:01 AM   #5
Lux3m35i
Lux3m35i's Avatar
Luxembourg
13
Drives: E92 335i Coupe
Definitely OEM plugs. Turbo engines are sensitive when it comes to the ignition system. OEM plugs do have the correct characteristics and are proven for the engine. Just make sure that you change them earlier when running a tune.
      06-27-2013, 10:10 AM   #6
N8N
N8N's Avatar
Drives: 2009 E92 335i 6MT
Damn, that's a legitimately good question, and I don't know the answer to it. I have no idea what the optimal indexing would be on a DI engine. However, seeing that these are multi-electrode plugs, I wouldn't worry about it too much - one electrode can't possibly be more than 60 degrees off of optimal even if you just slap them in without any regard at all to indexing; at the same time, you can't tell which electrode is going to fire during any given combustion event.
If you don't like paying the money for OEM plugs there is a Bosch equivalent that is indistinguishable. Don't have the part number handy but you should be able to find it with a quick search.
      06-27-2013, 10:40 AM   #7
E90Company
E90Company's Avatar
Drives: Car
OEM is fine. Some use re-gapped NGK's and have had sucess.
      06-27-2013, 11:58 AM   #8
j1gilles
j1gilles's Avatar
Drives: 2009 335xi
Go with the OEM plugs.... Indexing plugs is more for top fuel dragsters and the OEM plugs use a 4 prong electrode so indexing is not needed. Colder plugs are not needed unless you are running upgraded turbos and they tend to foul at a much faster rate.
ASE master tech (many moons ago)335xi- JB4 G5 iso/e50 custom flash/Custom meth/Borla mids/Custom x-pipe/DCI/ER charge pipe/Dual Ebay BOV's/Alpina B3 flash/Paddle shifter retro fit
      06-27-2013, 02:55 PM   #9
Snaggletooth
General Nuisance
That's the reason I ask.. I'm gonna be running some hybrids soon at around ~18 or so PSI. How cold would you guys go in this case?
'07 E92 335i 6MT
      06-27-2013, 03:29 PM   #10
j1gilles
j1gilles's Avatar
Drives: 2009 335xi
On my GN I went one step colder but I was pushing 20+ PSI. Im not an expert on these cars but I think this plug question is personal preference. Some people stick with OEM with hybrids, others go with the NGK one step colder.
      06-28-2013, 08:11 AM   #11
Alexm007
Alexm007's Avatar
Drives: '19 G01 X3, 09 E70,07 E92 335i
IIRC My 2007 N54 uses Bosch (#ZGR6STE2) Best prices from Amazon, ECS tuning, etc. Sometimes sets of 6 cost more than 6 individuals, so be careful!
Alex
Current: 2019 G01 X3
Before that: 2009 e70 X5
Before that: 2007 BMW 335i Coupe - ZSP
      06-28-2013, 08:15 AM   #12
AndyR83
AndyR83's Avatar
60
Drives: E92 335i FBO
I changed my plugs yesterday. I am running NGK 5992's (one step colder) at OEM spec gap (0.7.) I had a rough idle before, and now everything is perfect!
e90post
