E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Cobb AP P30FF WTF !
      06-25-2013, 06:31 PM   #1
Malaka1
Malaka1's Avatar
Drives: F30 335i 6MT Black
Cobb AP P30FF WTF !
So I have been getting the P30FF code I took my car to a local BMW performance shop and they found a vacuum line leak.. Ok so after that the boost came back. But now when I do long 3rd gear pulls it will trigger the P30FF code, I clear the code and hit it but it is like the car is still in safety mode? I have to turn off the engine and turn it back on and then it goes back to normal of course until I do a long 3rd or 4th gear pull. I have attached 2 datalogs below both of which I believe show the car throwing the code mid pull.
Just .csv files could use some help making it look like a datalog come on Cobb get your own datalog viewing software!
      06-25-2013, 06:37 PM   #2
e46m3to335i
e46m3to335i's Avatar
Drives: 2015 F80 M3
Maybe a boost solenoid needs replaced?
-Nick
      06-25-2013, 06:39 PM   #3
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Logs won't help us. You need to find the new boost leak.
      06-25-2013, 06:48 PM   #4
VNeBLOB42
VNeBLOB42's Avatar
Drives: 14' GMC Terrain SLT-2
007 335i E92  [7.66]
I've gotten the P30ff code under heavy load post shift when S1+ was freshly flashed. After adaption, went away. Check you vacuum lines and CP o ring and FMIC connections.
Search for Virtual Dyno, that'll read your csv files.
SOLD:: PTF Pro eTune by Dzenno / COBB S1+ E50
Alpina B3 Flash / ETS FMIC / ER CP / CPE DCI
      06-25-2013, 07:23 PM   #5
Malaka1
Malaka1's Avatar
It is well adapted by now over a month.
I will take it to check for another boost leak, smoke test and hope I find some thing that would be the easiest solution really.
Maybe wastegates are sticking?
      06-25-2013, 07:27 PM   #6
Malaka1
Malaka1's Avatar
Virtual Dyno I downloaded it but how does it read the .csv files? I open them in virtual dyno and nothing...
      06-25-2013, 07:27 PM   #7
marv85
marv85's Avatar
70
Drives: '07 E92 335i MT
1)post turbo boost leak
2)DVs
3)Boost control: vacuum lines from canister to engine, canister to solenoids, solenoids to WG
4)boost solenoid (that was my problem)
if all above don;t solve it then it's your WG actuators
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar.
'05 C55 AMG
SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT COBB, FBO, st2 LPFP, Mfactory LSD | '07 E90 335i, PTF COBB E50, FBO, HFS4
      06-25-2013, 07:31 PM   #8
Malaka1
Malaka1's Avatar
Nvm I got it
      06-25-2013, 07:35 PM   #9
VNeBLOB42
VNeBLOB42's Avatar
007 335i E92  [7.66]
Nvm I got it
It's a bit glitchy sometimes you just got to do the right steps
      06-25-2013, 09:52 PM   #10
gtaccord
Drives: 2009 BMW 335xi
Check your dvs and charge pipe first. Most leaks seem to be around there. Then check the vacuum lines that go to the boost control solenoids. A tiny leak will cause the problem you are having. I had the same issue and it took me quite a while to find. Buying a mightyvac to troubleshooting with would probably be a good idea.
      06-25-2013, 09:58 PM   #11
Chicks-Love-Bimmers
Chicks-Love-Bimmers's Avatar
Drives: FBO 335i
2007 E92 335i  [0.00]
Same thing happening to me I replaced both boost solenoids but my car is still getting the code. I'm pretty convinced its the wastegate actuator which is going to be a pain to replace since I'm FBO and I don't think the dealership will replace it
e90post
