do i need PROcedeFlash DME Reflash ?
06-24-2013, 02:32 PM | #1 |
Rep 189
Hi guys,
I see vishnu is selling PROcedeFlash DME Reflash on top of the vishnu v5. I have fbo car would it benefit me in any way? Thanks Dan |
06-24-2013, 02:51 PM | #2 |
Rep 2,172
Fueling ~ If you'll be running high Ethanol content and you're maxing out your fuel trims you'll need a backend flash to open up fueling tables. This can be done using COBB also if you want to stack your tune. You can also wait for OpenSource.
06-24-2013, 03:23 PM | #3 |
Rep 497
I wondered about this as well. There is a non e85 flash for gas (in CT we have 1 e85 station). Would the flash provide us with any noticeable gains or is more for those maxing fuel tables in the adjustable settings?
08' 335xi 6MT Space Metallic Grey Premium, Nav, Cold weather, Sport Procede 2.5, DCI, Forge DV, PWM, Scoops, KW V1, ETS 5" FMIC, VRSF Downpipes, M3 Skirts |
06-24-2013, 04:02 PM | #4 |
Rep 1,079
Just log and look at your fuel trims. If you're maxing them out at +34%, you probably need it. For example, my car pegs fuel trims on 91 alone, unfortunately. This does NOT imply that if they're maxed at 34%, this is the only solution. There are other things you can try to change to address the issue first.
06-25-2013, 07:55 AM | #5 | |
Rep 189
Thanks ill check it out
