06-24-2013, 08:29 AM | #1 |
Rep 4,721
Coolant leak
This is what I found this past weekend when I popped open the hood. I have already spoken to my Service Advisor (actually, Service Mgr) and he confirmed it's coolant leak. You guys may want to check yours.
11-09-2013, 06:08 PM | #2 |
Rep 327
Drives: 2017 Tesla Model X P100D
Had same problem and had no idea until I took engine cover off and saw leak. Never smelled it or saw it on ground, or smoking etc.
Dealer fixed under warranty. Parts Used: 1 x Feed Pipe 11 53 7 844 268 1 x Return Pipe 11 53 7 844 269 4 x Hose Clamp 32 41 1 131 346 |
11-09-2013, 06:15 PM | #3 |
Rep 1,246
Drives: 2015 LBB F85 X5M
mine was leaking too.
i had low coolant fluid warning. dealer fixed under warranty. |
11-09-2013, 06:24 PM | #4 | |
Rep 4,721
Mine was originally repaired with the same factory clamp. They then test pressured it and it failed to hold and leaked again. They had to use clamp with tightening type of screws (double) to fix it, now it has been about 5 months and all are good. No more leak.
11-12-2013, 06:12 PM | #5 | |
Rep 327
11-12-2013, 07:53 PM | #6 |
Rep 4,721
The service advisor said it was standard procedure as per requirement.
Either my dealer were simply following proper protocol or they went beyond the scope of warranty work. |
01-02-2020, 05:18 AM | #8 |
Rep 19,435
01-02-2020, 12:31 PM | #9 |
Rep 122
