cobb accessport
06-23-2013, 08:05 PM | #1 |
Rep 888
cobb accessport
Just wondering, is the cob ap itself considered stage 1, or is the stage one more of an upgrade? I am definitely going to VAC motorsports to buy a cobb ap this week.
Also, with an automatic, in perfect conditions, what kind of 0-60 numbers and quarter mile numbers can you see with just the cobb ap? |
06-23-2013, 09:02 PM | #3 |
Rep 236
Comes with a bunch of different maps. You just need to select the one that fits your octane / mods and enjoy.
2011 TiAg 335is -->2015 Range Rover Sport
06-23-2013, 09:26 PM | #4 |
Rep 170
Cobb AP itself is a handheld computer which you plug into your OBDII port with a provided cable and use it to flash your car's ECU. Go to their website and do some reading.
06-23-2013, 09:40 PM | #7 |
Rep 6,136
06-23-2013, 09:46 PM | #8 |
Rep 888
06-23-2013, 09:53 PM | #9 |
Rep 170
If you stick with Stage 1 maps ONLY, you don't need any other mods. That means you can't use "Stage 1 +" maps. You'll need a better FMIC for those. There is a map table on their website that tells you which map can be run with which mods.
06-23-2013, 09:56 PM | #10 | |
Rep 913
http://www.cobbtuning.com/BMW-N54-Ac...maps/bmw/IJE0S |
06-23-2013, 09:58 PM | #11 |
Rep 488
Drives: 2008 335xi E90
I recall my Stage 1 0-60 times were like 4.8 sec when I first got the Cobb with no other mods on my auto xi E90. I've now seen 4.2 sec with Stg 1+ and E85 and several other mods too. Make sure to get the Apex wheels on non-run flats too (Michelin PSS) that Vac sells too. They did a great job for me with my KW coilovers back in 2009. Good luck!
MHD Self-Tuned Scaled FlexFuel Map | M-Boost | N20 Tmap | Helix IC | Fuel-It Stage 2 LPFP | BMS DCI | BMS Thermostat Delete | CP-E Charge Pipe | Tial-Q BOV | Apex Arc-8 Hyper Silver | Michelin PSS | Cool Carbon Brake Pads R/T | SS Brakelines | ECS 2-Piece Rotors F/R | xHP Stage 3 | xDelete Sport | KW-V1 Coilovers | Turner Strut Brace | Lux Angel Eyes | CF Kidneys | Scoops
06-23-2013, 10:07 PM | #12 | |
Rep 888
06-23-2013, 10:19 PM | #13 |
Rep 913
09-16-2013, 11:23 AM | #16 | |
3441
Rep 79,211
Cobb is fairly easy to uninstall and reinstall IMO it's not worth the risk if you want to keep your warranty. Although some dealers are more lenient then others. Last edited by Jeff@TopGearSolutions; 09-16-2013 at 12:11 PM.. |
09-16-2013, 11:30 AM | #17 |
Rep 10,120
09-16-2013, 11:40 AM | #18 | |
Rep 4,392
It all depends how good of a relationship you have with your SA and the shop Forman. If you don't, then play it safe. |
01-01-2014, 05:27 PM | #19 |
Rep 1,733
Drives: 2003 M3
Couple questions:
What is the difference between stock and linear throttle? Putting the car back to stock with the AP is untraceable by the dealer? Thanks! |
01-01-2014, 05:41 PM | #20 |
38
Rep 634
Stock mapping is more aggressive. Less pedal travel results in more requested power.
Linear throttle mapping is more conservative and, to some people, more predictable. No-one that has uninstalled their AP before a dealer visit has ever reported that the dealer determined they have had a tune installed much less had any warranty issues. |
01-01-2014, 06:23 PM | #21 | |
Rep 1,084
I have an upgraded intercooler as well and stage 1+ was an even larger jump. Generally speaking the more supporting mods you have, the more aggressive tunes you can run. I uninstall my cobb when brining my car in for warranty work. I saw you asking about 0-60 times as well...I have a PTF custom map for my car/current mods (e92 AT 335xi intake, intercooler, oem run flats) using the AP 0-60 tool, I consistently clocked 3.7-.8 times Hope this helps |
01-03-2014, 10:50 PM | #22 |
Rep 1,733
Drives: 2003 M3
The inter cooler is not frowned upon at the dealer?
