Installed DPs... Multiple warning lights
06-23-2013, 09:32 AM | #1 |
Rep 167
Someone tell me they just need to be reset. I've got e- brake, check engine, traction, and brake caution lights on now.
06-23-2013, 10:56 AM | #2 |
Rep 709
Drives: LeMans 335i M-Sport Coupe
Do you have a tune, what are the codes?
E92 335i FBO ///Msport w/Meth+
06-23-2013, 11:23 AM | #3 |
Rep 167
Jb-4 haven't read the codes. Need to get the USB ordered now.
06-23-2013, 12:09 PM | #4 |
Rep 709
USB cable is not needed, you can check them manually. Just have pen/paper handy because they sweep pretty quickly...
06-23-2013, 04:28 PM | #5 |
Rep 775
Have you driven your car for more than 2 minutes yet?
14' M235I | BMW Performance Exhaust | BMW Performance Diffuser | BMW Performance Carbon Interior | ER DP |
JB4 S2 | BC Forged HB29's | N54Tuning.com | getBMWparts.com Current: 2015 Cayman S on HRE P101 |
06-23-2013, 08:11 PM | #7 | |
Rep 709
If your going to get DP's then, some sort of tune is a must!!
06-23-2013, 08:15 PM | #8 | |
Instagram: @Marcadelic
243
Rep 2,697
http://www.e90post.com/forums/showthread.php?t=480565
| New: 2018 F80 M3 | Old: 335i / 335is | Instagram: Marcadelic | |
06-23-2013, 08:26 PM | #9 | |
Rep 709
06-23-2013, 08:31 PM | #10 |
243
Rep 2,697
06-23-2013, 08:49 PM | #12 |
Rep 913
If you use the appropriate cobb dp map, you will not get any down pipe errors. But yes, cobb can clear codes as well, though not auto clear - I don't think.
06-23-2013, 08:56 PM | #14 |
Rep 913
You need to load the map appropriate to the mods you have and the octane you will be using. The maps are all free. their site lists the maps and mods/fuel required to run each map.
06-23-2013, 09:09 PM | #15 | |
Rep 409
Waiting to see if I can get some install quotes before I order, any guidance on how much a downpipe install should cost? |
06-23-2013, 09:34 PM | #17 | |
Rep 709
I have no idea what it would cost you....maybe 300ish.. I installed my own, DIY said to set aside 3-4 hours, lol took me about 7 but i had to get away from time to time due to frustration issues... I run the BMS DP's and cant complain one bit.... Very satisfied!
06-23-2013, 10:33 PM | #18 | |||
Rep 639
07 e92 335i | BSM | SB | Gray Poplar Wood Trim | 6MT | Premium | Sport | Cold Weather | iDrive | Logic7 | Comfort Access |
06-24-2013, 10:25 AM | #19 | |
Rep 409
I haven't ordered anything yet, since the downpipes are on backorder and I am waiting for some more cash so I can get the jb4 at the same time. Have you passed emissions with the G5 board? The only other thing that worries me with the Jb4 is pulling wires out in the ECU, did you DIY the jb4 install? |
06-24-2013, 10:31 AM | #20 |
Rep 409
argh, more conflicting answers! I know the previous G4 board did not have a dpfix, but BMS is advertising that G5 does. I dont want to spend the extra $100 if I don't have to, but the car needs to be able to pass IL emissions. I am aware that autoclear is very different than the emissions readiness codes, and with autoclear only you will not pass. One is to delete the CEL, the other is to set emissions readiness.
06-24-2013, 10:33 AM | #21 | |
Rep 639
all the jb4 does is reset the catalytic system so CEL does not show. Your system will not be ready for inspection. There are plenty threads about this.
06-24-2013, 10:40 AM | #22 |
Rep 639
Here's a thread that will help you understand it.
http://www.e90post.com/forums/showth...=jb4+emissions
