Low pressure sensor and crankshaft code... Just replace sensors?
06-22-2013, 08:19 AM | #2 |
Rep 7,377
i guess you are tuned considering the 2D18 code? you need to add ALL INFO about the car. not only codes. Also try to search them here , you will find tons of threads with troubleshooting help.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
06-22-2013, 08:48 AM | #3 | |
Rep 955
06-22-2013, 01:27 PM | #4 |
Stupid Idiot
134
Rep 827
Yes, you need to replace the low-pressure sensor. The 2A99 is not being caused by the crank sensor. Probably related to the vanos on the exhaust cam. Possibly a vanos solenoid issue.
06-22-2013, 03:53 PM | #5 | |
Rep 3,456
Drives: Harrop E90 M3
