06-20-2013, 08:10 AM | #1 |
Rep 453
Negative Camber
How much negative camber did you folks get in the front of your cars after installing H&R Sport springs? I'm considering doing this project, but the goal is to get some negative camber up front. What is your experience?
Thanks! |
06-20-2013, 07:34 PM | #2 |
Rep 210
I don't have an answer to your question. However, within the next two months, I believe there will be at least two camber plate options for you (ie., Ground Control and TC Kline). I'm not certain, however, whether they would require a coilover set up or whether you could run stock. If you are interested, you may want to call them. Two others who may be out with camber plates in the coming months are AST and Vorshlag...but not sure on any time table for them. Regarding Vorshlag, one of the main guys there just chimed in on our camber plate thread indicating they are moving up their plans to for a camber plate on the F30: http://www.f30post.com/forums/showthread.php?t=800665
SCCA & Midwestern Council W2W, '91 Spec Miata, '07
NASA TTD Champion, Midwest, '99 M3, '09 Midwstrn Council TT Champion, BS, '10 GTI, '10 &'11 Midwestern Council TT Champion, BS, ‘17 BRZ, ‘19 Last edited by JMK007; 06-20-2013 at 07:40 PM.. |
06-21-2013, 08:51 AM | #3 |
Rep 453
Thanks! My bmw dealership tech, who builds and campaigns bmw's with NASA, tells me the strut top design is going to make camber plates really tough to do on the f30. As a result I am looking for another option...if somebody does it, I can always add them on later.
The lack of camber destroyed my 'kook z-214's so I want to find an interim solution. The lower control arm from the e90 M3 was the right shape and length, but the bushing end was just that little bit too fat to fit in the chassis. Maybe a moderate drop will get me just enough to help without destroying the street ride quality? Worth a shot IMHO! Thanks for the feedback! Enjoy your event this weekend. |
06-20-2014, 12:57 PM | #6 | |
Rep 1,436
http://www.cambertire.com/ |
06-20-2014, 02:02 PM | #7 |
Mmmm... Bavarian
2129
Rep 1,690
We've tested these out at my local SCCA and they are awful.
M2 CS
2023 CB X5 45e 2018 i3 94 2014 Cayman S |
06-20-2014, 04:28 PM | #8 |
Rep 1,649
I can't seem to find the thread right now but I saved the part numbers in a doc on my desktop in case I lost track of the thread so that is paying off now. :-D there are some factory pieces you can put on to give you some more negative camber. here is what I cut and pasted from the thread:
Part # is the same across the line-up (335i, 328i, standard/sport/adaptive) RWD 31-21-6-854-199 left -30min $211.19 31-21-6-854-200 right -30min $211.19 hopefully that helps. |
06-20-2014, 10:28 PM | #10 |
Mmmm... Bavarian
2129
Rep 1,690
I was not one of the guys that got to run them, but the guys who did said the performance was WAY off top notch tires. The grip of the compound was not there. Additionally turn in and road feel was pretty poor. I can query the guys and see what I get back for you.
Thanks! Steve
M2 CS
06-20-2014, 10:54 PM | #11 |
Mmmm... Bavarian
2129
Rep 1,690
Got one bit of feedback back already. I was correct on the compound. He also said that they required a lot of camber on the car as well to work, which sort of defeats what you are probably looking for.
M2 CS
06-21-2014, 10:54 AM | #13 |
Rep 1,436
so if I get a camber kit front & rear with good run-flats or none will be better ?
06-23-2014, 03:35 AM | #14 |
Rep 4,516
More negative camber - will F8x M3/M4 lower control arms - tension struts work ?
Hi,
In pursuit of more camber but using OEM parts has anyone got anymore info on use of F8x M3/M4 LCA and TS on F3x series front suspension to push bottom of hub carrier further outwards ? Attached photo of underside of new M3 - looks v similar..... Comments/advice most welcome.....
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
06-23-2014, 04:55 PM | #15 |
Rep 1,649
found the thread I mentioned above if you are looking for OE parts to increase camber:
http://f30.bimmerpost.com/forums/sho...ghlight=camber may do these to mine at some point. |
08-14-2014, 03:42 PM | #16 | |
Rep 4,516
Std fit Mich PSS outer shoulders have softer compound hence wearing quicker and why I'm keen to dial in more negative front camber. Keen to know if F8x LCAs etc are the oem solution ..... |
