E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Jb4 problem
      06-19-2013, 11:56 PM   #1
SGJB135i
Drives: Jet black 135i
Jb4 problem
Hey guys, I keep installing my jb4 and a few weeks later I keep getting a check engine light and it's a misfire cylinder. My car has 90k miles right now. I believe my dealer changed my cylinders but I maybe wrong. But is it the jb4 messing up or it's just my jb4? I never had a problem when my car was stock but with the jb4 its giving me a problem. Please someone let me know ASAP, thank you.
      06-20-2013, 12:09 AM   #2
TTurbo335
TTurbo335's Avatar
Drives: BMW 335i
http://www.e90post.com/forums/showthread.php?t=631829
When's the last time you changed the spark plugs? Where in Cali are you located?
      06-20-2013, 12:26 AM   #3
E90Company
E90Company's Avatar
Drives: Car
They changed your cylinders??
If you can read the codes and post them here, we can give you more detailed help.
      06-20-2013, 01:43 AM   #4
SGJB135i
P305 cylinder 5!
      06-20-2013, 01:44 AM   #5
SGJB135i
30k miles. I will change those soon
      06-20-2013, 08:59 AM   #6
_ink
Jedi samurai ninja turtle
_ink's Avatar
Australia
619
Drives: X3 M40i 2018
2018 X3 M40i  [0.00]
Plugs and/or ignition coil.
      06-20-2013, 10:06 AM   #7
M3_Dylan
Drives: 2008 BMW M3
+1
KW V3's / AA Stage 2 Supercharger / Catless Mid-pipes / AA Mufflers / Apex Arc-8's / PFC 09's
      06-20-2013, 04:25 PM   #8
Indo Rider
Drives: 135
So you have 60K miles on the plugs? If that's right you should definitely change those as a first step.
      06-20-2013, 08:43 PM   #9
vanondemand
vanondemand's Avatar
Drives: E92 335i M/T
2007 335i  [0.00]
check your coils!!!! make sure they are not damaged.
      06-24-2013, 09:40 PM   #10
SGJB135i
Sorry guys i forgot the dealer changed my spark plugs 2000 miles ago. This happens to my car often and I take off the jb4 and it is good to go with no problems. Anyone else have expeirnce with this?
      06-24-2013, 09:44 PM   #11
litxus
Drives: 09 E90 335i sedan
Try replacing the coil first (cylinder 5) and see if that does the trick. If not it could be injectors starting to go (did you get yours replaced by recall?).
      06-24-2013, 09:45 PM   #12
135Pats
135Pats's Avatar
Drives: A few BMWs
Its a tune induced misfire, likely something with your ignition is not up to snuff. If plugs are that new, replace the coilpack.
      06-24-2013, 09:47 PM   #13
SGJB135i
yes it went through the recall. I doubt it would be the injectors.
      06-24-2013, 09:47 PM   #14
SGJB135i
Im just going to try to switch around the coils. It is off my car right now, but i will put it back on soon. Thank you.
e90post
