DAB retrofit - questions?
06-16-2013, 11:38 AM | #1 |
Rep 1,235
I am looking to do a DAB retrofit pretty soon and just had a few questions which someone in the know may be able to help with. My car is a LCI and I have the Pro Nav CIC with Combox doo daa factory installed.
From what I gather, there is mixed info on whether you must have the mustard connector at the back of the unit or not. Can anyone clarify? Also is there a easier way to tell whether my unit has the necessary DAB antenna connectors without removing the unit (I only want to disturb the unit when I do the retrofit as rattles are my pet hate!). I'm familiar with coding it all up so that's all fine, but the next question is the antenna. Am I right in thinking there is two options for this... 1. run the dab antenna wire to the back of the car and buy a BMW diversity antenna, suitable for DAB). 2. Go for a windscreen stick-on antenna (I'll probably go for the most discreet one possible and go with this in the interim, until I can find a cheap enough diversity DAB antenna as they are £275 new ) Appreciate if someone can shed some light on this. |
06-16-2013, 11:52 AM | #2 | |
Rep 9,097
1- Find a CIC with DAB. 2- Code that CIC to the VIN of you car. If you cannot do that, then unfortunately you will have to use the emulator.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
06-16-2013, 12:10 PM | #3 |
Rep 1,235
Thanks for the response. I think i'll have to just pull my CIC out and see what connectors are there (wishing the mustard connector is there ) before shelling out on a replacement CIC unit.
