F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > M Performance Rocker Panel Film
proTUNING Freaks
      06-14-2013, 09:42 PM   #1
fricfracfrank
fricfracfrank's Avatar
Drives: 2019 X3 M40i
Does anyone have the instructions for installation of M Performance Rocker Panel Film. Apparently it should come when ordered but was not supplied from getbmwparts.com
Present: 2019 X3 M40i Phytonic Blue
Past: 2013 335i xdrive Estoril Blue
2011 328i xdrive Black Sapphire Metallic
      06-15-2013, 07:34 AM   #2
fricfracfrank
My weekend project hangs in the balance...
      06-15-2013, 12:22 PM   #3
Chris@codemybimmer
BimmerPost Supporting Vendor
Chris@codemybimmer's Avatar
Drives: AW F30 328i Xdrive
it works like any other vinyl...
two methods:
1) wet install: use water spray onto the rocker panel and the back of the vinyl , align everything and squeeze out the water with a squeegee and wait for dry (blow dry to speed things up)
2) dry install: start from one side of the panel, attach and use a heat gun to slowly go over and slight stretch the vinyl until you're done and no bubbles
      06-15-2013, 04:05 PM   #4
GuiltyNL
Drives: F31
There is a manual, ask your dealer. The paper backer is used to align the film, so don't cut it. Wet is the easiest, use special application liquid instead of water / soap.
Use a heat gun to dry it faster, the film will go into the curves of your skirt, so a heat gun is handy. Don't forget to use a rubber squeegee to push excess liquid out.
      08-18-2013, 06:03 AM   #5
SteveChester
SteveChester's Avatar
Drives: F82 M4
2014 BMW F82 M4  [0.00]
Anybody got this manual?
Steve Roberts UK
F82 M4
I'm running the 2024 London Marathon for the British Forces Foundation - https://www.justgiving.com/fundraising/sr5/
      12-29-2013, 08:44 AM   #6
AWMSPORT
1ST CLASS AWMSPORT
AWMSPORT's Avatar
Drives: 13' 328 MSPORT
The dlrship has the manual on hand? IS there any specs of the vinyl? Size??
'13 328i MSport, AW, Black Dakota leather, Premium Pkg, xenons, ///M Perf, side skirts,Front Lip, Fully coded, CF roundels, Matt Black Grillz, Painted reflectors (front & rear) Smoked tail lights, Plazma l.E.D White PY27W front turn signal,trunk spoiler, Matt Black roof, 8K D1S HID,Custom Exhaust,!
Soon:
JB4,DP,H&R sports,rear diff,!
      12-31-2013, 12:34 AM   #7
Jvee90
Drives: 2013 328i, 2008 335i sedan
found this thread to be helpful. http://www.f30post.com/forums/showthread.php?t=845082
had my dealer install it. they used a third-party vendor that ended up putting one side lower than the other--made them redo it. they too did not have instructions. second time around, they used the top of the decal to measure against vs the bottom…they claimed that the logo was printed in different locations (one higher, one lower) which caused the misalignment.
f30post
