2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wash, Wax, Detailing and Cosmetic protection/repairs DIY Keep Leather Seats & Interior New...Forever
      07-22-2010, 05:48 PM   #1
gatoman39
gatoman39's Avatar
Drives: 2011 E92 335 M-Sport
Once every other month or so. It depends how dirty you are or if you have kids, etc. I would use a quick detailer to spot clean, but when I'm feeling saucy...The leather on this car is very nice and high quality and you can keep it this way by doing this:
I'm all about Lexol. You really don't have to do too much with this car. It's pretty easy, since it's new. Problems occur with negligence, which is basically the same with everything in life....
1. Bowl filled with distilled water (you can use tap).
2. Spray bottle distilled water
3. Sponge
4. Microfiber Towels (lots)
5. Cotton Terry or MF applicator rounds.
Cleaning:
Shop Vac interior, especially the seams,stiching and crevices. Dip sponge in water, spray Lexol cleaner into sponge, wring out most of moisture. Prep leather by misting with water. Work cleaner into a light lather, don't need to get leather soaking wet. Wipe off with micorfiber towel. Let fully dry.
Conditioning:
Mist applicator with distilled water on both sides. Moist not damp. spray 2 or 3 squirts onto the applicator and spread evenly on leather surface, doesn't need to be dripping wet. Allow to dry. Wipe off excess with MF or terry towel.
**You can get an all in one from Lexol, but I'm not into jack of all trades master of nothing products. But if you're lazy, it's better than nothing
All rubber and Vinyl Parts can be hit up with Vinylex, wipe on and off. Use Stoners invisible glass for the windows/mirror, safe for tint. All clear plastic like the NAV screen or tint can be cleaned with Plexus.
      07-24-2010, 06:43 PM   #2
Whteverjklasdf
Drives: .
get the 3M film that blocks 99% of the ultraviolet.
      08-15-2010, 09:34 PM   #3
blulite
Drives: 2011 550i
What do you use on the wood? I've got the dark wood, and it's a dust magnet. Takes about 15 minutes and it's coated again. At the moment I'm using a damp micro-fiber cloth, then dry with micro-fiber. I'm thinking some type of anti-static cleaner, but I'm not sure best to use.
      08-15-2010, 09:41 PM   #4
gatoman39
gatoman39's Avatar
It's coated with plastic, so you can use a plastic cleaner Meguiars makes one or you can use plexus, but actually neither is necessary. Just use water or a quick detailer. The Plexus does have anti-static component, but it's pretty expensive.
      10-12-2011, 02:05 PM   #5
Jim_in_Calgary
Jim_in_Calgary's Avatar
Drives: 2011 535xi MSport - TiAg
I wouldn't use Meguiar's clear plastic cleaner for this application. It is an abrasive compound (like a rubbing compound) and too aggressive. I have the black (bamboo anthracite IIRC) and a moistened good quality microfiber towel buffed with a dry microfiber towel does very nicely.
08 BMW K1200S / 2002 330ci Sport (sold) / 1989 635csi (sold)
07.5 GMC Sierra 2500HD Duramax LMM
09 Honda Odyssey EX-L
'75 Ford - Early Bronco
      10-12-2011, 04:14 PM   #6
gatoman39
gatoman39's Avatar
You are right to be confused due to the word "cleaner". I'm using it literally and you're using it in a product branding sense. The product I suggested is a clear plastic cleaner, and has no abrasive qualities, but is called "Plastic Detailer". The product you are thinking about is the clear plastic prep product #17 which is used to prep for the polish.
      03-11-2013, 11:18 PM   #7
khanyam4
Ring Leader of G8X Trolls
khanyam4's Avatar
Cambodia
802
Drives: NA
definitely something to do.
      03-14-2013, 12:00 PM   #8
Sleuth
Drives: Tech-540i
Leather Food
Conolly ..out of england is the best I have ever used..lasts
File Type: txt Connolly Hide Care.txt (68 Bytes, 183 views)
