Lowering springs Help required
06-09-2013, 08:09 AM | #1 |
Rep 614
Currently got 313 19" wheels on the car, and although I wasn't planning on dropping the car, I've decided to get some lowering springs. (Dont want to go down the coilover route at this point).
Any suggestions on make? Want a nice drop, but wih no rubbing/ minimal rubbing when loaded. I will be putting spacers on with the drop. (Currently have 20 on rear, but these rub even with standard springs). Although sits nice and flush. Thanks
Cree angel eyes - 19" 313 OEM alloy wheels - 15mm rear spacers - Black performance Grilles - Alloy pedals - Tinted windows - Shadowline trim - M3 rear Spoiler - Tail light mod - LED interior lighting - k&n panel Filter - Performance Diffuser - Carbon Badges alround - Bluetooth - Air intake scoops - Painted Calipers - Custom Stainless Exhaust
06-09-2013, 01:12 PM | #2 |
Rep 3,194
Drives: E92 325i MSport Coupe
The two favorites are H&R or Eibach. Do bear in mind your ride quality will deteriorate. I would advise changing the dampers at the same time and if you want OEM ride (or better) try Koni FSD dampers.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
06-09-2013, 01:18 PM | #3 |
Rep 614
Yeah the ride quality always does. My audi TT is pretty low, so used to the lower ride quality. I'll try the two you mentioned, and see how it goes. Thanks
06-09-2013, 04:31 PM | #4 |
Rep 5,623
I put on ACS lowering springs on my previous E90. These springs are specced by AC Schnitzer and manufactured by Eibach. Ride quality was nice, very close to OEM. I didn't change the dampers at the time, but if i did it again i would.
06-10-2013, 02:17 AM | #5 | |
Rep 8,970
Lowering a car won't ever cause more rubbing as it doesn't move the wheels position in or out. Think about it, all you're doing is moving the car further down it's suspension travel, if the car doesn't rub now when you bottom out coming off a speed bump etc then it won't rub when it's lowered will it? Fitting spacers can cause rubbing though even on a standard height car during compressions. You have 20mm rear spacers - what about the front? it must look a bit unbalanced with big wide rears spacers? It will really dull the steering too, adding understeer with wider rear track. Depending on your wheel offsets, but 10mm spacers all round gives a good look, no rubbing and keeps both front and rear track in proportion, preserving front/rear balance. Just don't overdo the spacers - one for us oldies Last edited by doughboy; 06-10-2013 at 02:29 AM.. |
