E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > ...
      06-06-2013, 07:12 AM   #1
bmwkong
Drives: Bike
      06-06-2013, 07:22 AM   #2
lemonukas
Drives: 325i e91
Look for another independent specialist.
      06-06-2013, 07:22 AM   #3
lemonukas
Drives: 325i e91
Or do it your self.
      06-06-2013, 07:40 AM   #4
zltm089
zltm089's Avatar
Drives: 335i SE Coupe Space Grey
2006 BMW 335i  [10.00]
where are you based mate?
      06-06-2013, 07:44 AM   #5
xenon
xenon's Avatar
England
1397
Drives: 2021 G21 330i M-Sport
The garage is talking bollocks. The shoes are used for the handbrake, nothing more, so unless you drive around with the handbrake on there should be no wear to the shoes. Pads and disc swap on a lift is less than an hour.
Ian
Current: 2021 G21 330i M-Sport
Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2
      06-06-2013, 08:58 AM   #6
dest
dest's Avatar
Drives: LCI E91 320d M Sport
Discs won't have shoes for the handbrake, that's just for rear drums!
      06-06-2013, 09:43 AM   #7
greatbm
greatbm's Avatar
Drives: G15 840i Coupe
BMW set up is internal handbrake shoes in most of its range. Shoes situated internal to brake disc.
      06-06-2013, 10:04 AM   #8
dest
dest's Avatar
Ah ok, so basically a pad on the inside then
      06-06-2013, 10:38 AM   #9
parapaul
parapaul's Avatar
Drives: E91 330d M Sport
Yes - discs and pads for braking, then shoes inside the hub for the parking brake. Because the shoes aren't ever used for normal braking they should last the life of the car.
Just how many Yorkshire sheep can you fit inside one exhaust?
      06-06-2013, 11:13 AM   #10
greatbm
greatbm's Avatar
Recently changed all discs and pads, rear handbrake shoes were as new but handbrake has never been exceptional from new. Spec is to adjust up to lock wheel and back off 8 teeth, adjusted mine to 5 no binding and a much better result, went through MOT just after with no problems.
      06-06-2013, 04:06 PM   #11
zltm089
zltm089's Avatar
Originally Posted by bmwkong View Post
Based in Leicester...and yeah Iv read up on shoes and think the garage is talking b0ll0cks too.
Just had another quote from concordeautocentre.....£225 for discs, pads, sensor (no shoes)...pagid or OE equivalent. Seems more realistic and will probably go with them now.
You know anyone in Leicester ?
damn....no sorry mate...
only garage i know of up north is darren wood
      06-06-2013, 04:13 PM   #12
kevin@bndynamix
Drives: combo van
Around £210 all in at my inde using pagid or textar, shoes, discs, pads and sensor.
e90post
