F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > BMW 320i Dyno Results!
proTUNING Freaks
      06-05-2013, 05:48 PM   #1
Mike@N54Tuning.com
BimmerPost Supporting Vendor
Drives: 2007 335i, 2015 M3
For those not familiar it's an N20 motor rated at around 185hp from the factory.
It's been rumored that it's basically identical to a 328i only detuned from the factory and so far BMS has not found anything to disprove that. From the factory it runs a modest 8psi and feels like an absolute slug. Stock dyno numbers at 183whp confirmed its neutered status. The factory 328i does ~235rw for comparison.
Initially the Stage1 tune was installed using the default +3psi settings and it perked up to 212whp. At the higher +4psi settings we got 220whp. Pretty close to 328i numbers. Not bad for a simple to install inexpensive upgrade.
After the Stage1 testing BMS threw on the BETA Stage2 for a little fun. There is still plenty of work to do but was rewarded with a best of 266whp showcasing this platforms potential. Up next BMS needs to richen up the air/fuel targets on Stage2, take direct control of the electronic wastegate, and finally do some E85 tuning.
      06-05-2013, 07:03 PM   #2
Alpine F31
Alpine F31's Avatar
Drives: MB E350 4MATIC Estate
I see it's from Calabasas..... wouldn't that be an N26? I thought that was a California thing....
In any event, those are impressive numbers!
      06-05-2013, 08:26 PM   #3
StealYourFace
Drives: F30 328i M 6mt, E36 M3
Nice... and the lease deals on 320i are tempting...
Any chance you guiys will tune the Mini Cuntryman All 4 S? My s.o. neads a new car and is leaning in that direction... tuning would make it more tempting
      06-05-2013, 08:26 PM   #4
krnnerdboy
krnnerdboy's Avatar
Drives: v10 m6
So aside from the smaller diffs and brakes it seems to be an identical car for quite the bargain. Had this been available 2 month ago I would've optioned for the 320 then
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm
Gone:z4m, boss 302, c6 z06, m6,z3m
      06-05-2013, 09:31 PM   #5
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
Don't forget about the pistons.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      06-05-2013, 10:30 PM   #6
RSXDC5
RSXDC5's Avatar
704
Drives: M3
Do know how many mm smaller?
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs
      06-06-2013, 12:07 AM   #7
clarence
Drives: F30 328i M-Sport
It's not the size it's the shape.
      06-06-2013, 12:28 AM   #8
1bad335
Drives: 2007 335I/ 2012 335I sportline
Those numbers are pretty damn good. For early stages that is impressive.
      06-06-2013, 01:14 AM   #9
aspang86
aspang86's Avatar
Drives: 2012 BMW 320i
That is amazing!! In all my posts and vids i have strongly supported bms stage 1 tune once i installed it. I can definitely feel that huge gain in power. Iam currently using 94 octane fuel in my 320i and running the default tune setting. Iam averaging 730km a tank!!! Cant wait for the stage 2 kit. What type of fuel will we have to use?!? Back to the piston head topic, is the piston made of the same material and just a slightly different shape to up the compression? 266hp is a lot on the engine. Iam not sure how stable it would be on the rest of the drivetrain.
      06-06-2013, 02:21 AM   #10
Nikor
Nikor's Avatar
Israel
Drives: F30 320i
Mike
I have been waiting for this update for a couple of months now.
I got my 320i on January and i ordered my BMS stage 1 at the same time but haven't installed it yet, i wanted you guys to actually try yet on the 320i first.
Now i can install it without hesitation. i would appreciate if we can use this thread as an official one for the 320i drivers.
i would also appreciate if you can upload a pic of the complete setup figures for the 211 setup plus the 220 for reference before i install my kit.
Shay
      06-06-2013, 07:28 AM   #11
mkmm
Drives: F30
Nice number and Well done...Mike! eager to look forward for the release of Stage II.
      06-06-2013, 07:49 AM   #12
jcastle
jcastle's Avatar
Finland
Drives: 2013 BMW F30 320i M-Sport AW
Intresting numbers indeed, nice job!
Once you get some more knowledge, it would be intresting to know what are stable whp numbers i.e. what can we expect on normal Stage 1 (?).
Also, don't forget the smaller diameter exhaust (320i/60,2mm vs. 75mm/328i) and a smaller cat-back. I am sure this has some effects on performance in everyday use.
2013 BMW F30 320i - M-Sport, Alpine White, M Sport suspension and brakes, Sport AT, VSS, PDC, Xenon, High-beam assistant, Harman/Kardon, Extended BT, Rims 403M (summer 19") and 397 (winter 18"), M Performance: Exhaust, Rear Bumper Diffuser, Carbon fiber mirror caps, Carbon fiber rear spoiler, Black kidney grilles, Floor mats. 3M Brushed Black Metallic vinyl wrap roof.
      06-06-2013, 09:30 AM   #13
aspang86
aspang86's Avatar
Guys the half shaft concern is not an issue. Dont let people fool you! As long as your not power braking and trying to perform burn outs all day long your half shafts will hold up. I had a dodge charger rt and the srt guys always told me about how much cooler there half shafts were. 210whp is nothing for those shafts. The concern we should have is the tranny. Is there any differences from the 320-328i in terms of transmission components?
Also in terms of exhaust, nobody has posted solid numbers for exhaust gains. If you want to see a noticeable increase, i would suggest you to get a new down pipe. Good luck passing emissions laws though.
      06-06-2013, 01:43 PM   #14
cooler2442
Drives: 1/18 Monte Carlo Blue E92 M3
Great numbers on the 320i. To make 266whp with stage 2 is definitely impressive. I'm now leaning towards this than a 328i if the engine can hold the power.
      06-06-2013, 03:30 PM   #15
momo3605
Drives: M340i LCI, 718 GTS 4.0
How is this car making the same as stage 2 on the 328i?
Looks like stage 2 for the 328i needs some more r&d
      06-06-2013, 05:03 PM   #16
BRM6
BRM6's Avatar
Brazil
11
Drives: 328/335/M235i/M4 - Current M6
We would love to know the following:
1) Is the 320i engine the same as the 328i engine? Internals and all!?
2) Is the turbo the same as the 328i?
      06-06-2013, 10:06 PM   #17
mkmm
Drives: F30
Hi Mike, figures given are dyno with mod 320 downpipes?
      06-06-2013, 11:29 PM   #18
aspang86
aspang86's Avatar
I think we should all be concerned about adding too much boost to our turbos. They can only handle so much. I think stage 2 might be really pushing its limits. I am assuming will have to use e85 fuel mixture. Our compression ratio is going to demand it. 266whp is almost a 90whp increase!!! Thats like an extra 120hp at the crank
If we can get some solid info on our drivetrain parts than this may be the ultimate deal breaker to buying a 320i. ppl can save thousands and get almost same performance of a 328.
      06-07-2013, 09:04 AM   #19
brunox2
brunox2's Avatar
Brazil
17
Drives: BMW ///M3 E92 AW
Beautiful!!!!
08' BMW ///M3 E92 AW
      06-07-2013, 09:15 AM   #20
ScarecrowBoat
Zooombie attaaack!!
ScarecrowBoat's Avatar
Drives: 328
It's not, the 328i makes 300rwhp/350rwtq........
      06-07-2013, 09:46 AM   #21
Mike@N54Tuning.com
The car is 100% stock other than the tune. No downpipe installed, although when they are done with the 320i Stage2 tuning they will put one on for addl testing. Since the motor is basically identical to the 328 once the tuning details are worked out they should make the same power.
Mike
      06-07-2013, 09:49 AM   #22
topcat87
Drives: F30
328i's 300whp is on map 1. The 320i was dynoed on map 5
f30post
