Add 1 litre of oil - oil level decreased rapidly - leak?
06-03-2013, 09:56 AM | #1 |
Rep 313
November 2012: noticed the oil level has been "slowly" decreasing over the past few months / weeks and the "Add 1 litre of oil" message appears. Take the car to the BMW dealer to get a litre top-up (which I have to pay for - I read some dealers do this for free?) and the mechanic notices some leaking and the vacuum pump and rocker gasket cover needs replacing.
January 2013: get the pump and cover replaced at the dealer. The oil level is back to the maximum on the iDrive screen. February 2013: notice the oil level has gone down 2 squares on the oil level meter which has never happened so fast in the 6 years of having the car. I get the car checked at the dealer - report is no leaks. April 2013: near end of April after not driving for 2 weeks - driving for 50 miles the message for 1 litre comes on. Hmmmm. May 2013: depending on the day the oil level is OK (but near the minimum level) or some days "Add 1 litre of oil". June 2013: for the past few days the "Add 1 litre of oil" is always coming on. I only do 6500 miles a year and the oil level has never gone down so quick in previous years. My gut feeling is the vacuum pump and rocket gasket cover has not been done 100%. Or the oil sensor for the "electronic dipstick" is faulty? Should I "Add 1 litre of oil" or see the dealer asap? The owner's manual says you should drive the car a max of 125 miles or engine can be damaged. I know BMW say 625 miles can give 1 litre of oil consumption but the level has never dropped so quick! Any help please! http://www.e90post.com/forums/forumdisplay.php?f=2 Am I allowed to post the same message above in the general E90 forum or is this spamming? Non-UK people won't read this forum? |
06-03-2013, 12:23 PM | #2 |
Rep 9,097
Check:
1- Vaccum pump and the area below it for any oil. 2- Areas below the rocker cover gasket for any traces of oil 3- The gasket below the oil filter for any oil 4- VANOS solenoid and surrounding - What sort of mileages do you have on your car? - Any other sign / symptoms? - Has your MPG gone down lately? If all the above is fine, then most probably your oil level sensor is faulty.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
06-10-2013, 05:32 AM | #3 |
Rep 313
Thanks; went to the dealer and they found some leakage of oil so they are going to sort this out. As it happens a couple of days before the oil level went below the minimum - the iDrive display of the vertical meter had just 2 squares and it had turned red - I suddenly topped up with a litre of Castrol Edge Professional in the boot.
My question since this drop in the oil level is due to the dealer not doing the vacuum pump / rocker cover gasket 100% properly as there's now a leak can't I ask for a "free" litre of Castrol Edge Professional (costs £17) because it's their fault I needed to top up?!?! Anyone know the difference between Castrol Edge and Castrol Edge Professional - the Professional is only available via the dealer. --- - What sort of mileages do you have on your car? 52000. - Any other sign / symptoms? Noticed the exhaust a bit "white smokey" few months back when this started - could be the cold winter temperatures? - Has your MPG gone down lately? No nothing abnormal. |
