E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > E92 Rear centre console courtesy lights?
      06-01-2013, 09:54 AM   #1
maurauth
black
maurauth's Avatar
England
Drives: Jerez Black E93 M3
So I was replacing all my courtesy lights with LEDs yesterday- got all the rooflining down etc etc but when I got to the rear courtesy lights in the centre console that light the footwell area I popped it out but found no way into the unit.
Has anyone found a way of replacing the bulbs in these units or is it just not worth the effort?
      06-01-2013, 11:53 AM   #2
acerboo
England
179
Drives: e92 335d lci
the are changeable but when I put leds in mine I found there to be less light so I put the bulbs back
      06-01-2013, 12:53 PM   #3
maurauth
black
maurauth's Avatar
England
How did you get to the bulb because when I popped the fitting out it was one solid unit with a white plug in the back?
      06-01-2013, 02:51 PM   #4
bmwak
bmwak's Avatar
Drives: 440i M-Sport Gran Coupe
Have a trawl through the light bulb section on here. Can't view it properly on my ipad. It's for the 330i but principle will be the same. Are you using the genuine BMW Led upgrade kit?
http://bmw.workshop-manuals.com/3_Se...ex.php?id=2451
      06-01-2013, 06:33 PM   #5
maurauth
black
maurauth's Avatar
England
Nah, I'm just using SMD LEDs off ebay from a company that do a year guarantee and are canbus error free.
I found the relevant section on that: http://bmw.workshop-manuals.com/3_Se...ex.php?id=2444
But it still is veeery ambiguous about how to get into the unit once you've removed it.
      06-02-2013, 12:27 PM   #6
acerboo
England
179
sorry cant actually remember how I did it but there are various threads under the cosmetics and lighting heading
      08-31-2018, 10:02 PM   #7
GB-335xiCoupe
Libertarian
GB-335xiCoupe's Avatar
Drives: 29k mi per year.
So I'm resurrecting this thread because I'm doing the same - replacing everything with LEDs -
The center console courtesy lights in the back seat are the final replacement. I was able to open the housing to get to the bulb by using a small screwdriver and removing the lens, and then pushing out the base. The problem I am having now is identifying the bulb itself so I can find an LED replacement. The printed info on the bulb itself is SO TINY!
WTF are these bulbs, and what is the LED equivalent? Bueller?
2011 335xi Coupe BSM (e92/N55/ZPP/ZCW, Alpina B3 Flash)
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi
Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k
Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k
e90post
